2500 dd - Car Audio Classifieds!
Old 09-26-2014, 01:40 AM
Brand New Members
0/11 ssssssss4
Default 2500 dd
Woofer Brand: DD
Model:2500
Do you have more than one of these subwoofers used in the same installation? If so, how many?no
How much power does the/each subwoofer need to handle? (RMS power)1k
What impedance will you need (Per voice coil)?2ohm
The brand, model, and quantity of amplifiers that you'll use?soundstream trx1000d
The impedance at which you plan to run each amplifier?1 ohm
The type of enclosure that it needs to work in? (Sealed, ported, bandpass?)ported
The size and tuning of the enclosure that it needs to work in? 5cuft 30-34hz
The type of music that you'll listen to with it?rap hip hop country
Will you be competing with it, or is it a daily usage subwoofer?Daily
Is it for competitions only? nope
Would you like any special colors? If so, where?no
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc?direct leads
Any other special instructions or requests?inverted dustcap
Where are you located?78415
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? send motor only
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with?no
thank for time and info PSI.
Old 10-03-2014, 11:43 PM
TeamPSI's Avatar
0/11 sssss4041
I just sent you a PM with the price and address. Thanks
-David Moore
Old 10-04-2014, 08:48 PM
Brand New Members
0/11 ssssssss4
Thanks for the quick response and information.
Old 10-05-2014, 10:14 PM
TeamPSI's Avatar
0/11 sssss4041
no problem
-David Moore
dd 9500 h Stonepatterson General Car Audio Discussion & Questions 5 12-15-2013 11:06 PM
DD 9500 G and DD 9500 i motors to be built bump4life Speaker Accessories & Parts 14 11-19-2013 11:34 AM
dd 9500 BallzFast (Fix My Speaker) 35 01-23-2012 07:44 PM
dd 9500 bassking_dubs64 General Car Audio Discussion & Questions 16 07-22-2011 12:31 PM
