Quote - Car Audio Classifieds!
Old 10-21-2014, 02:43 PM
0/11 sssssss20
Default Quote
Woofer Brand: Hifonics
Model: Goliath xx3215
Do you have more than one of these subwoofers used in the same installation? If so, how many? Yes, 2
How much power does the/each subwoofer need to handle? (RMS power) As much as possible ?
What impedance will you need (Per voice coil)? Dual 1
The brand, model, and quantity of amplifiers that you'll use? 2 American Bass VFL 500.1
The impedance at which you plan to run each amplifier? .5
The type of enclosure that it needs to work in? (Sealed, ported, bandpass?) 4th Order
The size and tuning of the enclosure that it needs to work in? 4/12 Peaks at 37
The type of music that you'll listen to with it? Decaf
Will you be competing with it, or is it a daily usage subwoofer? Both
Is it for competitions only? No
Would you like any special colors? If so, where? No
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? Direct leads
Where are you located? 40220
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? I would like a quote on both options, drop in recone and sending them to you.
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? Potentially, see above.
Old 10-24-2014, 08:48 PM
TeamPSI's Avatar
0/11 sssss4041
I'm sending you a PM with prices
-David Moore
Sub Quote enemyofsilence (PSI Car Audio) 1 07-11-2011 01:36 PM
quote levee000 (PSI Car Audio) 1 07-11-2011 01:04 PM
Quote please RXZILLA Toolmaker Price Quote Section 1 07-08-2011 11:29 PM
Another Hc Quote please SUPER_YOCOM (Fix My Speaker) 3 05-11-2011 11:50 AM
Need quote on box. Requesting quote 72impala Off Topic Chat 1 06-07-2010 10:28 PM
