RE XXX 04-05 drop-in - Car Audio Classifieds!
Old 12-03-2014, 07:54 PM
0/11 ssssss586
Default RE XXX 04-05 drop-in
Woofer Brand: RE Audio
Model: XXX (v3) 04-05 with rounded bottom plate with 10" 12 spoke aluminum baskets
Do you have more than one of these subwoofers used in the same installation? If so, how many?
A: Going to be two
How much power does the/each subwoofer need to handle? (RMS power)
A:2k
A: Dual 2 ohm
A:Single MMATS HD4000.05
A: .5 ohm
A: ported
A 4.5-5 cu. ft. @ 30-34 Hz suggestions would be greatly appreciated
A: all types, lots of hip hop and 28 Hz tones
A: Daily street beat
Is it for competitions only?
A: no
No.
Will purchase dustcaps, terminals, glue from your online store.
A: Match Fi prices?
A: I know theres lots of ways you can go about the parts as far as spider count, but I was thinking 2 spiders, but want to maintain close OEM specs
Where are you located?
A: OH
A: kits sent to me
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with?
Will purchase rubber adhesive, CA, dustcaps, terminals exc. from your store.
Will be using 10" 12 spoke baskets per sub. Need a quote for just one, and will need an identical drop in for the future.
Really would like to have a black spiders if possible.
Old 12-03-2014, 07:59 PM
0/11 ssssss586
Really hope you can help me out with parts for these Dave =] I'm sure you have a couple laying around to model these =]
Old 12-03-2014, 11:35 PM
TeamPSI's Avatar
0/11 sssss4041
PM sent with some info.
-David Moore
Old 12-04-2014, 09:23 PM
0/11 ssssss586
Thank you for your quick response.
I may go with the 12" cone after all then.
Custom drop in recone for 15'' 2005 RE Audio XXX and Ti Basket **Pics** zeuslicious Speaker Accessories & Parts 26 10-02-2014 11:39 PM
FS: SS XXX Motor + SS XXX 15" Basket + Recone + More **Pics** zeuslicious Speaker Accessories & Parts 15 03-01-2013 11:10 PM
Quote for (2) 2005 RE Audio XXX 18" Drop in recones HelloImBob (Fix My Speaker) 1 06-30-2011 12:15 PM
SoundStream XXX 15's & 2 XXX-6500D amps AtomicInstalls Wanting to Buy (WTB) 22 10-24-2010 09:57 PM
04/05 XXX motor/ SS XXX basket 1ndatrunk General Car Audio Discussion & Questions 29 10-21-2010 12:27 AM
