soundstream xxx 15" drop in - Car Audio Classifieds!
Old 01-12-2015, 02:07 AM
spl_robb's Avatar
0/11 ssssss571
Default soundstream xxx 15" drop in
Hi Dave, need a drop in recone for this sub,
Thanks in advanced.
Woofer Brand: SOUNDSTREAM
Model: XXX-15
Do you have more than one of these subwoofers used in the same installation? If so, how many?
A: ONLY ONE
How much power does the/each subwoofer need to handle? (RMS power)
A:4K
A: ITS OK IF ITS DUAL OR QUAD COIL, NEED .5 FINAL DCR
the brand, model, and quantity of amplifiers that you'll use?
A:Single PB xta4000d
A: .5 ohm
A: ported
A 3.5-4 cu. ft. @ 30-34 Hz suggestions would be greatly appreciated
A: all types, lots of hip hop and LOW STUFF
A: Daily street beat AND COMPS
Is it for competitions only?
A: no
A: DIRECT LEADS
Where are you located?
A: CALI
A: kit sent to me
(2)10" Mids (2) HornsD290Py S (2)TW 700Ti all PRV
2 x 18" DSS SAVAGES/2 x SOUNDIGITAL 12K @1 ohm
4 BANKS OF SCAPS/ shca ofc cable wire 4 runs.
Old 01-14-2015, 02:18 PM
TeamPSI's Avatar
0/11 sssss4041
Thanks I sent you a private message about this
-David Moore
FS: Soundstream XXX 15" Craig28 15" Subwoofers 70 11-18-2011 06:54 PM
Soundstream XXX 18"!!!!!! TeamPSI (Fix My Speaker) 2 08-11-2011 05:11 PM
Quote for (2) 2005 RE Audio XXX 18" Drop in recones HelloImBob (Fix My Speaker) 1 06-30-2011 12:15 PM
soundstream xxx 15" motor aleroking Speaker Accessories & Parts 49 01-05-2011 08:13 PM
SoundStream XXX 15" x 4 QUOTE xx-wade-xx (Fix My Speaker) 1 12-01-2010 01:21 PM
