Recone quote - Car Audio Classifieds!
Old 02-01-2015, 10:25 PM
thekernal123's Avatar
0/11 sssss1813
Default Recone quote
Woofer Brand: diamond
Model: d6
Do you have more than one of these subwoofers used in the same installation? If so, how many?no
How much power does the/each subwoofer need to handle? (RMS power)1500rms
What impedance will you need (Per voice coil)?d2
The brand, model, and quantity of amplifiers that you'll use?N/A
The impedance at which you plan to run each amplifier?1
The type of enclosure that it needs to work in? (Sealed, ported, bandpass?)ported
The size and tuning of the enclosure that it needs to work in? Tuned low
Is it for competitions only? Daily
Would you like any special colors? If so, where? Red psi dustcap
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc?direct leads
Where are you located?60113
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you?send to me
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with?glue and shims
To make sure that we can take care of your needs as quickly as possible, please make sure to answer any questions that we ask to the best of your ability. The more information that we have, the better and more quickly we can help you.
Please post or send photos of the actual subwoofer so that we can verify the exact motor, frame, and parts spacing. We cannot build drop-in recone kits without first receiving photos of the subwoofer, and sometimes require photos before an exact price quote can be determined.
98 blazer dc 320amp alt 1xs d3100 a 2 type r 15 d4 at 1 ohms on a AQ 3500 doing a 148.5 at 41htz so farrr gotta do some adjustments
Recone quote My69dart (Fix My Speaker) 3 04-04-2012 01:38 AM
Recone quote Kian_NJ (Fix My Speaker) 7 05-16-2011 08:51 PM
Recone Quote AFlem (Fix My Speaker) 3 05-10-2011 02:43 PM
recone quote tuckin-taco93 (Fix My Speaker) 0 12-08-2010 08:21 PM
quote for recone donkryder954 (Fix My Speaker) 2 03-10-2010 08:18 PM
