Earthquake Magma's 12"! - Car Audio Classifieds!
Old 03-30-2015, 10:53 PM
ludeman's Avatar
0/11 ssssss467
Default Earthquake Magma's 12"!
Woofer Brand: Earthquake
Model: Magma
Do you have more than one of these subwoofers used in the same installation? If so, how many? 2
How much power does the/each subwoofer need to handle? (RMS power) 1500rms
What impedance will you need (Per voice coil)? D4
The brand, model, and quantity of amplifiers that you'll use? Sundown 3500
The impedance at which you plan to run each amplifier? 1
The size and tuning of the enclosure that it needs to work in? 3c/f tuned to 32hz
The type of music that you'll listen to with it? Hiphop
Will you be competing with it, or is it a daily usage subwoofer? Daily
Is it for competitions only?
Would you like any special colors? If so, where? No
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? High roll surround
Any other special instructions or requests? Basket are permanently attached to motors and spider landings are 7.5"! Can you use the adapter for them to accept an 8" spider?
Where are you located? 21060
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? I can if need be
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? No
Ray
Old 04-05-2015, 10:43 PM
TeamPSI's Avatar
0/11 sssss4041
Model: Magma
We have never rebuilt the Magma series before but judging by the looks of it, I'm pretty sure that we can do it.
I'm not sure about the spider size. We do have a ring that increases the spider diameter, but it requires that there is an extra deep distance between the spider and surround landings.
Basically, for me to know if we can use the spacer or if we can rebuild these with nice high-power parts, I'd need for you to measure the gap and the distance on the frame. I can send you a diagram that shows which measurements you'd need to take. You need to use a caliper for the motor gap measurements and a ruler and straight edge for the frame measurements. Please try to get as accurate as you can.
just to give you a good idea were estimate, I'd say that we could rebuild these with high power flatwound coils, the biggest spider possible whichever that may be, sewn heavy duty single leadwires, HD pulp cones with tall roll surround, and polypropylene dome dustcaps for an estimated cost of $280 for the pair, plus shipping costs.
http://fixmyspeaker.com/pdf/Recone%20Measurements.jpg
http://fixmyspeaker.com/pdf/Gap%20Measurements.jpg
Thanks,
FixMySpeaker.com
-David Moore
Old 04-05-2015, 10:45 PM
TeamPSI's Avatar
0/11 sssss4041
p.m. sent
-David Moore
Old 04-06-2015, 09:33 PM
ludeman's Avatar
0/11 ssssss467
Well do!
Ray
2 Earthquake HoleeS 15"s stssilverado 15" Subwoofers 6 05-09-2014 08:38 PM
Earthquake PA4300 "Worlds Most Powerful Amp" 4 X 380 watts at 4 ohm on 12 volts iamsonic eBay 0 09-28-2012 11:25 AM
Earthquake PHD2 "shredder" with toolmaker inputs Old skool junkie Mono Amplifiers 0 04-11-2011 12:58 AM
[FOUND] Old grey Earthquake D2 "Shredder" ghostmechanic Car Audio Trader (WTT) 7 07-26-2010 03:04 PM
Earthquake Holee S subwoofer 15" "old school" 15000 w KellerWebDesigns Bargain Bin 7 03-02-2010 11:57 PM
