JL 13W7 Recone - Car Audio Classifieds!
Old 08-13-2015, 11:53 PM
lexington_86's Avatar
0/11 ssssss174
Default JL 13W7 Recone
Woofer Brand: JL Audio
Model: W7
Do you have more than one of these subwoofers used in the same installation? If so, how many? 1
How much power does the/each subwoofer need to handle? (RMS power) 1500ish
What impedance will you need (Per voice coil)? D1, Sending Coil to you
The brand, model, and quantity of amplifiers that you'll use? 1 MMATS M3000.1
The impedance at which you plan to run each amplifier? 2 OHMS
The type of enclosure that it needs to work in? (Sealed, ported, band pass?) Using PR's
The size and tuning of the enclosure that it needs to work in? 35HZ, 2 cu ft
The type of music that you'll listen to with it? Rap, R&B, Dubstep, anything with bass
Will you be competing with it, or is it a daily usage subwoofer? Daily
Is it for competitions only? No
Would you like any special colors? If so, where? No
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? Full cone cover with small white PSI sticker if possible also my cone cover is cracked and has a hole. I'm hoping you have something that will work
If you have a budget to keep, what is it? $150
Any other special instructions or requests? Sending new cone to you
Where are you located? 79904
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? Sending sub to you
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with?
Old 08-14-2015, 09:55 AM
0/11 sssssss37
Huh this lost me is this a invoice
Old 08-14-2015, 10:39 AM
0/11 ssssss174
No, its a request for service.
Old 08-14-2015, 10:52 AM
0/11 ssssss512
i paid like 120-150 for a re coil kit from them for that same woofer just coil with spider and leads
so idk if there gonna be able to do a complete recone for that much id just take the primary dustcap off paint the cone and run a carbon fiber dust cap thats what i did with my w713.5
Old 08-14-2015, 11:22 AM
0/11 ssssss174
I'm sending them the cone and coil. I just need the spider and a cone cover because mine is in bad shape.
Old 08-26-2015, 12:47 PM
TeamPSI's Avatar
0/11 sssss4041
PM sent
-David Moore
JL 13w7 Papered_Up Other Size subwoofers 1 01-18-2014 06:15 AM
jl 13w7 jeremylevib Other Size subwoofers 0 09-22-2013 08:27 PM
F/S JL 13w7 Loud and Proud Other Size subwoofers 46 05-21-2012 10:08 AM
13w7 ( i know) marcotheclepto (Fix My Speaker) 2 03-23-2011 09:44 AM
Jl 13w7 crownvic97 General Car Audio Discussion & Questions 7 06-28-2010 07:14 PM
