f-150 - Car Audio Classifieds!
Old 05-17-2009, 02:56 PM
scfaust's Avatar
0/11 ssssss848
Default f-150
i was driving my f-150 today and was cruzin and it just stoped i pulled over in a back p/l i tryed to start it it just crancked the fuel pump kicks on after about 1 hour it tryed to start but dint i checked the spark no spark my wife went to wait for the tow truck about 2 hours later it started but died we got it back home changed the batt it started for 1 min quit no spark ........... could the coil be bad or the modgule or the distributor? help please i think if it was the cain it wouldent start back up at all right
Old 05-17-2009, 02:57 PM
No, I'm not dead
0/11 sssss8128
Sounds like the module might have died.
Old 05-17-2009, 02:58 PM
scfaust's Avatar
0/11 ssssss848
would it still try to start fromm time to time then?
Old 05-17-2009, 03:02 PM
No, I'm not dead
0/11 sssss8128
My '80 chevy with the HEI did when it killed modules. They'd get hot and stop working and start again after a while. I replaced the coil after the 2nd module thinking the coil was shot but it happened again.
Old 05-17-2009, 03:04 PM
what year truck
Old 05-17-2009, 03:06 PM
scfaust's Avatar
0/11 ssssss848
Old 05-17-2009, 03:14 PM
0/11 ssss31257
Your options are as follows:
1) your wires are bad. more specifically your coil wire.
2) your coil is bad.
3) your distributor cap and rotor are bad
4) your ignition control module is bad and when it warms up, it quits working.
5) your fuel pump is the real problem.
Your ignition control module is on the drivers side fender.
It takes a 5.5mm nutdriver or socket and ratchet to remove it.
most parts stores stock it.
Old 05-17-2009, 03:20 PM
scfaust's Avatar
0/11 ssssss848
^^^^^^^^^^^^^^^thats funny thats what im going to do is start replacing them parts id like to start with the most likely one so thats why i asked
Old 05-17-2009, 03:22 PM
first go under the truck there is a 14ga wire on the starter replace that I had to 3 times on mine and it's a 96
Old 05-17-2009, 03:26 PM
scfaust's Avatar
0/11 ssssss848
^^^^^^^^^ did ur still crank when the wire was bad^^^^^^^^^^
