Alarm wiring info requested... - Car Audio Classifieds!
Old 01-30-2012, 11:10 AM
jmelton86's Avatar
Something clever.
0/11 ssssss626
Default Alarm wiring info requested...
1994 Geo Prizm Alarm, Remote Starter, Keyless Entry Wiring Information
"Door Trigger" -I would use this for the sensor wire to make the alarm go off when the doors are open, correct?
"Parking Lights" -I would use this to make the lights flash when the alarm goes off, correct?
"Trunk Pin" -I would use this to make the alarm go off when the trunk is opened, right?
If I'm right about the above, could I splice into both the "Parking lights" wire and the "Trunk release" wire for the same signal sensing wire on the alarm?
CDA-9855 PDX4.100 GTO14001
Tuning low is great.
KeepItSimpleStupid
Old 02-08-2012, 12:22 PM
0/11 ssssssss8
Are you installing a two way alarm system that gives you visual notification to what set off the alarm? If so you do not want to combine your trigger inputs into one.
You also do not want to combine your parking lights and trunk release wire to sense the alarm.
The Parking light wire from the alarm is an OUTPUT to meant to turn on the OEM circuit. Where the Door and Trunk triggers are INPUTS to the unit.
Also the Parking light OUTPUT from the unit is going to flash the lights when you arm/lock, disarm/unlock or the alarm goes off, so combining all the wires is not going to work.
Hope this helps
Old 02-08-2012, 12:35 PM
jmelton86's Avatar
Something clever.
0/11 ssssss626
I used the wiring diagram from the12volt.com and I had it installed in like 2 hours LoL
Piece of cake, by the way.
Thanks.
KeepItSimpleStupid
alarm instal help Blaza33 General Car Audio Discussion & Questions 0 01-27-2012 05:38 PM
best car alarm to get? got160s? Off Topic Chat 32 11-29-2010 10:49 PM
deciding on an alarm? fyerbyrd22 General Automotive Chat 20 09-28-2010 10:19 AM
alarm kingmade08 General Car Audio Discussion & Questions 12 04-14-2010 10:12 PM
alarm help 99vic General Automotive Chat 1 01-28-2010 12:00 AM
