My car won't stay running. Help - Car Audio Classifieds!
Old 02-03-2012, 11:34 PM
SPLpizzaguy's Avatar
Humbled by CACO
0/11 sssss3111
Feedback Score: 57 reviews
Default My car won't stay running. Help
It turns over but then engine stops running. I am sure it had a quarter tank. I put another gallo9n in and the gas light does not even work. It is like it is not getting any fuel. It a 2004 malibu classic
4 sa10s
Taramps 8k
4 American Bass VFL 6.5s
Ohio Generator 305 amp alt
4 Vifa Tweets.
Old 02-03-2012, 11:41 PM
mtrevino92's Avatar
0/11 sssss1527
Feedback Score: 21 reviews
Same problem here, I was told that it was my coil pack or something like that. I'm having my vehicle towed to the shop in the morn to get a second opinion. 96 GMC Suburban 5.7L.
Old 02-03-2012, 11:50 PM
Humbled by CACO
0/11 sssss3111
If it was mycoil pack I doubt it would turn over and run.
4 sa10s
Taramps 8k
4 Vifa Tweets.
Old 02-03-2012, 11:52 PM
Nik592's Avatar
0/11 sssss2000
So it starts and then dies right away is what your saying?
Have you let it die lately? (battery)
Or changed the ECU/PCM or anything?
"Insert witty signature here"
Old 02-03-2012, 11:53 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
have someone turn your car on while u open your gas tank like your gonna put gas in it and listen for the fuel pump....you might have to stick your head under the car i do not know.....when you turn all your accesories on the fuel pump should make a buzzing sound if its working properly......or try pouring gas straight into the breather and see if she starts and runs for a second because that gas wont last long
Old 02-04-2012, 12:00 AM
Nik592's Avatar
0/11 sssss2000
Skar has the right idea and right around the same idea I'm thinking
Only difference is if the fuel pump failed, it probably wouldn't restart and then die every Time you turn it over
The problem I had with my jeep was that I changed the PCM, and it set the vehicle into security mode, the Jeeps factory security thought that it was being stolen and would cut the fuel supply off after a few seconds of running
What I did to fix it was have my installer at work look at it, and we grounded the factory security wire out in the drivers door panel
And voila, 2 weeks of problems saved by 10 minutes of finding the correct wire to ground
Just an idea.
Old 02-04-2012, 12:10 AM
0/11 ssssss209
my ram would start an run for a second and then die ended up being a plugged Cadillac converter
96 jeep grand cherokee 4.0l
Pioneer DEH-P7200HD
Stetsom 10kd, stetsom 1k6es2, stetsom vs400.4
4 mp-8's
2 skar vx4-st super tweeters
Old 02-04-2012, 12:13 AM
badmofo529's Avatar
0/11 sssss3329
LOL. catalytic converter.
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 02-04-2012, 12:16 AM
0/11 ssssss209
lol hey it looked good
Pioneer DEH-P7200HD
4 mp-8's
Old 02-04-2012, 12:18 AM
Humbled by CACO
0/11 sssss3111
Yeah it died 5 days ago I left the lights on.
4 sa10s
Taramps 8k
4 Vifa Tweets.
Car running cold? Container for engine coolant(antifreeze)? its_ray_ray General Automotive Chat 13 08-28-2011 07:52 AM
10/03/10 11:00 1 Stay Tuned Customs WAUKESHA WI 262-542-8863 FE+CS DP Stay Tu poundstone Competition Corner 15 10-01-2010 05:27 PM
Voltage Drop- Just Car Running brandonb1029 General Car Audio Discussion & Questions 7 09-18-2010 02:29 PM
Battery dies while car is running? taylorpro General Car Audio Discussion & Questions 19 09-07-2010 02:36 AM
what to look for and stay away from when looking at used subs hoefgenm General Car Audio Discussion & Questions 21 09-04-2010 04:16 PM
