Speedo gear swap in a TH200-4R HELP!! - Car Audio Classifieds!
Old 04-09-2012, 11:57 AM
Homernuts's Avatar
0/11 ssssss396
Default Speedo gear swap in a TH200-4R HELP!!
I recently changed my rear diff from a 2.73 to a 4.10, now I need to correct the speedo reading. The vehicle is a 87 Caprice wagon with a Olds 350/TH200-4R combo. I figured out how to remove the speedo drive gear that is attached to the governor, but can't seem to get the speedometer housing out to remove the driven gear. It seems to be just a pressure fit with an o-ring that holds it in, but that puppy is tight. Anyone else done this or know of any tricks?
Speedometer housing
Speedometer driven gear
Old 04-09-2012, 09:34 PM
0/11 ssssss226
Spray inside there with a penetrating oil of some sort (I tend to favor PB Blaster), then use a hook or a bent awl, as well as a pair of pliers or Vise-Grips.
Spray, rotate, pry. Repeat.
eBay Username -
The Following User Says Thank You to amalmer71 For This Useful Post:
Homernuts (04-10-2012)
Got some nice new gear in! Beerdrnkr General Car Audio Discussion & Questions 14 07-17-2011 07:56 PM
Does anyone mess with pa gear on here? More spl Off Topic Chat 8 04-25-2011 03:29 PM
need my tt gear??? audiobahnfan Team Teamless 8 09-14-2010 03:59 PM
DD gear quaddropper General Car Audio Discussion & Questions 24 09-05-2010 04:44 PM
Can miles on speedo go up when being dollied? westman995 General Automotive Chat 37 03-12-2010 11:14 PM
