Rear Shocks - Trunk sits too low - Car Audio Classifieds!
Old 05-21-2012, 11:01 PM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
Default Rear Shocks - Trunk sits too low
My trunk in my 97 grand prix gtp sangs way too low.
I'm wondering if someone could recommend some new shocks/air bags/ whatever you suggest to help fix this problem.
Here is some pictures of my current ones.
Also I would have to replace/fix this situation without getting into my trunk. Because my box will not come out of my trunk. I built it inside my trunk and it takes up 97% of it...
oh btw, if someone knows how to replace a stud for my lug, i'd appreciate the help(last picture)
Refs: BlackWaterOp x2, Master69 x3, Scottie x3, RidnClean, JusBlaze (Scammed Me), SPLaudio x3, ltr450racer690, dbeez, LuisT, SPY, Mgcauctions09 x3, pieper88 x3, scottyk, Jh8909, JB312, stretch, Mechman, 01SpyderDB23, andrewtexas123, 50 black guys, bubbagumper6, btr, SacTownBully84
Old 05-21-2012, 11:09 PM
Prohibited Sellers/Buyers
0/11 sssss1326
In for answers as my buick isn't liking the weight either
Old 05-21-2012, 11:11 PM
0/11 sssss1237
couple ways, bags that are filled with air rest underneath there and they inflate to whatever, or coilovers which fit over there and you can adjust them for proper weight, or just get better springs.
Old 05-21-2012, 11:13 PM
stylez12321's Avatar
0/11 sssss2192
Feedback Score: 37 reviews
On the wheel stud, since yours is all the way out. you should be able to go the parts store and get a new one. You will have to beat it in from the back.
Old 05-21-2012, 11:17 PM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
Which would be the best way? I was under the impression of a whole new suspension system for the back?
I assumed it would be something simple like that, but wasn't quite sure
Old 05-21-2012, 11:20 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
You gotta pull the caliper off and the rotor and remove the hub and get a stud and have it pressed in or smang it in with a hammer.
Either going to need stiffer springs or airbags prolly for the weight issue.
Old 05-21-2012, 11:28 PM
badmofo529's Avatar
0/11 sssss3329
air struts
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 05-21-2012, 11:36 PM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
Could anyone provide links to suggested ideas?
I don't really wanna spend over $100 for this, but my back end sits lower than my front end now lol
Old 05-21-2012, 11:38 PM
armykyle1's Avatar
GFY&FYC
0/11 sssss6187
Feedback Score: 23 reviews
you could try spring helpers
Team XS Power
Team Heavy Hertz
Build-
youtube-
Old 05-21-2012, 11:40 PM
Rayo187's Avatar
0/11 sssss1127
Feedback Score: 31 reviews
Default Coil Spring Specialties
These guys can custom make you Coil Springs for instances such as this...Where you a have a lot of extra weight in the trunk...
Let them know what your set up is...What you want...They can help you out..
They know what your current Spring Rate is..Just by the Make & Model of your car..
Just let them know about how much extra weight you have in your trunk..
If you don't know how much extra weight you have in your trunk??..
You could just have them make you Coil Spings with double your current Spring Rate..
Check them out...Whatever your needs are they can hook you up!
Their Custom Coil Springs are not really expensive either..
Click this link: Coil Spring Specialties | Request a quote
99-06 GM FS Drop Shackles, Shocks Matt3824 Miscellaneous Stuff For Sale 2 02-28-2012 10:06 AM
Air shocks? andrewtexas123 General Automotive Chat 6 12-27-2010 10:46 AM
Ported box for trunk with no rear shelf rachidfunaki General Car Audio Discussion & Questions 0 08-02-2010 03:17 PM
Forward vs Rear firing In trunk ascitiesburn69 Enclosure Discussion & Design Construction Help 21 09-23-2009 04:14 PM
rear hatches and trunk rattles Snwbrdr1 Sound Deadening & Fabrication 11 06-23-2009 11:19 PM
