Alternator or Battery dead? - Car Audio Classifieds!
Old 05-26-2012, 08:21 AM
garygross7's Avatar
0/11 ssssss305
Default Alternator or Battery dead?
The other day I blew a terminal off my battery. The zero gauge running from the alternator to the terminal must have shorted out somewhere. I was driving the car with the battery still in because it had two terminals for the positive, then my RPM gauge just drops to zero and my radio is cutting on and off and about 3 mins later it cut off. So I figured the alternator was bad but I took it up to advance auto and it tested good. So I'm lost on what's wrong. Because I also had them test the battery the day before and they said it was good just needed a little charge so I charged it before going out. Any ideas on what's wrong?
Old 05-26-2012, 08:36 AM
0/11 sssss3842
whats the battery resting voltage at idle? whats it resting at with car off?
Dustan sent me the pics of the terminal btw. very surprsed you didnt blow something up.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 05-26-2012, 08:44 AM
garygross7's Avatar
0/11 ssssss305
Yeah I got pretty lucky. And the car is about 45 mins away. But if the alternator was bad how would I have drove 45 mins and then it died. I had a marine battery in it but I think it's unlikely it kept the car going that long. I mean the alternator could have been trying to charge it and a cell in it was bad
Old 05-26-2012, 09:01 AM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
Gotta be alt.......try running car with nothing on....than turn headlights on and see if car dies or acts up
Youtube VIDz :
Old 05-26-2012, 09:04 AM
garygross7's Avatar
0/11 ssssss305
Should I just buy a new alternator even though it tested good? And I got to drive back up there and put it on to test it
Old 05-26-2012, 09:42 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Even if the alt dies the vehicle will still run for a period of time off the battery alone. Which is not good on the battery but can be done. And since it was a deep cycle marine battery that is most likely why it went as long as it did. But in the process you probably killed the battery.
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Most of the guys at advance auto,auto zone, W/e don't know WTF they are doing in the first place so i wouldn't trust their diagnosis. You might have a elecrtical shop around you that could test it right.
Old 05-26-2012, 10:03 AM
0/11 sssss3842
Yea sounds like u killed the alt. and possibly battery in the process
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 05-26-2012, 10:11 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
was the stereo bumping until it died? you should have turned the stereo off and the car would have kept running. the alt cannot handle the demands of the system by itself.the stereo caused the voltage to drop too low and the car died.
My game is legit,
Old 05-26-2012, 11:46 AM
garygross7's Avatar
0/11 ssssss305
well blacks is the local shop I bought it from. But they are closed for the 3 day weekend. I think one of the cells went bad in the battery and it wouldn't fully charge cause the battery light was on and when I accelerated the light when off so I figured the alt gave it more juice. And no system was hooked up yet.
do i have a dead battery? smokenyall General Car Audio Discussion & Questions 16 04-14-2012 06:38 PM
Alternator/Battery help bottlefed1 General Car Audio Discussion & Questions 12 02-19-2011 06:03 PM
Dead Battery? aviator08 General Car Audio Discussion & Questions 2 12-22-2009 08:06 PM
battery and alternator????????????? fyerbyrd22 New Member Orientation 2 10-05-2009 09:23 AM
