Front End Issue - Car Audio Classifieds!
Old 05-29-2012, 01:41 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
Default Front End Issue
97 s10 blazer, 2wd
I have a TERRIBLE shaking issue when I brake.
I got the car looked at and Les Scwhab told me it was the rotors, I checked em out and there is no wear on them, brake pads got alot of pad left. Also told me the wheels are bad and none of them match. So i swapped them out and now all tires match.
took it to another place to get em looked at and guy said bearing needed to be re-packed, so i got it done. They also said come in for an alignment cause it COULD be that or the front end alignment.
talked to a mobile mechanic who said it sounds like a rotor issue.
STILL have the issue, so im consulting the forum before i make my next move.
92 Ranger Walkthrough
(Under Construction)
Old 05-29-2012, 01:49 PM
0/11 sssss1068
A rotor can be warped and still look brand new. I would go that route. As far as re-packing the bearing that guy needs kicked in the head for saying that. If your bearing is going out trust me when I say this you will know. It's a very loud and f-Ed up sound. When you change the rotors buy new pads also. Don't use the old ones cause if they have a groove in the pad it will put that same groove in your rotor. I would get a alignment anyways to save the life of your tires and to prevent and severe front end damage. I hope this helps you out.
Old 05-29-2012, 01:55 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
it does help alot...thanks
Old 05-29-2012, 05:45 PM
massivespl's Avatar
0/11 sssss8409
ya had this problems before and it was a warped rotor... u can get warped rotors brand new out the box...
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
The End. terra General Car Audio Discussion & Questions 30 11-23-2011 02:57 PM
New changes, major front end redo... madmat Sound Quality Area 4 07-21-2010 03:40 AM
Front end w/ a 750s? Drewculous General Car Audio Discussion & Questions 9 01-12-2010 12:59 PM
