1997 ford mustang a/c problems - Car Audio Classifieds!
Old 07-10-2012, 10:59 AM
beatnbronco's Avatar
0/11 sssss2284
Default 1997 ford mustang a/c problems
okay, the a/c system is complete, has a new oriface tube and low pressure line, the only leaks are when the black plastic caps for the high side/low side bleed valves are removed. when i put a small can of r134a in, the compressor will turn on for just a sec and the system is in the red on the pressure gauge. should i check the condensor coil and evap canister, or are there any other troubleshooting steps i need to check? sorry, i'm just use to putting r134a in and it being good. i need to get this fixed so i can sell the car and put food on the table..thanks for the help
Old 07-10-2012, 06:45 PM
0/11 ssssss146
Are u making sure the clutch is spinning on the compressor before u add r134a? And the ac is on high/max?
Old 07-10-2012, 11:58 PM
0/11 sssss2284
the clutch won't grab till there's a certain amount of freon in the system, just speaking from my own personal experiance. the system is completly empty when i add freon, i've had to do some repairs to the engine that required evacuating the a/c system so everytime i charge the system it's completely empty and i'm putting in fresh freon, and the compressor only kicks in for a second then shuts off, then back on again for another second about a min later. i've tried blowing through the line and it's somewhat restricted..should it be that way or is there possibly some blockage? the tube that houses the oriface and the oriface itself is brand new
Old 07-11-2012, 12:09 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
The oriface tube is a restrictor. So yes, it should be kinda hard to blow through it.
Do you have mechanical or electric fans?
If electric is it spinning?
Are you putting the correct amount of freon into it?
Team CACO Team SHOK
Supporting Member
Old 07-11-2012, 12:53 AM
0/11 sssss2284
elec fan and 1/2 a small can of freon sends the pressure gauge all the way around to the pin till it can't go any further..tomorrow i'm going to use a different gauge incase this one is jack'd up
Old 07-11-2012, 12:55 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Is the fan spinning?
What's the low side say?
Team CACO Team SHOK
Supporting Member
Old 07-11-2012, 09:26 AM
0/11 sssss2284
maxx'd out! i even have the outside temp dial set
Old 07-11-2012, 09:34 AM
Dunder Mifflin
0/11 sssss1897
1/2 a small can you say ! Good chance you have a restriction in your lines or a fitting, and I don't know if the same applys to cars as house ac's but once you evacuate your system you need to vacuum it down and itll take all moisture out of the lines!
jordan i want my subs
Old 07-11-2012, 02:41 PM
0/11 ssssss146
may be a bad relay or a bad ac compressor altogether. The clutch will not kick on if its that low when ur adding freon, but once it has enough in it, it should stay spinning (while the settings are on high) while adding the freon, your gauge aint bad.
Old 07-11-2012, 02:44 PM
0/11 ssssss146
you are correct, once the system is evacuated, the ideal method is to pull vacuum and do a leak test, and then fully charge it.
Ford mustang console jwright0291 General Car Audio Discussion & Questions 10 10-03-2013 03:03 PM
1997 ford escort wagon! KEVGNAR Member Rides & System Pictures 24 04-15-2012 05:59 PM
1997-2004 mustang q-logic kickpanels fyerbyrd22 Wiring, Electrical & Other Installation Equipment 19 11-18-2011 11:14 PM
My 2003 ford mustang v6 and gt Cort3232 Member Rides & System Pictures 72 03-16-2011 07:24 PM
2000 Ford Mustang 3.8 /AT SPL_II Miscellaneous Stuff For Sale 26 02-11-2011 09:34 AM
