94 sonoma has problems getting into second - Car Audio Classifieds!
Old 07-15-2012, 11:04 PM
SPLpizzaguy's Avatar
Humbled by CACO
0/11 sssss3111
Feedback Score: 57 reviews
Default 94 sonoma has problems getting into second
bought it as is ( for teh cheapz). HAs not one spec of rust. undercarriage is still red and frame has no rust. car had come from texas and made its way to ohio. The problem with it is it does not really get into second without using the automatic shifter, and that is sometimes get into second, does have first and reverse though. I have heard it could be a couple things, the cab mounts, the shift solenoids or the whole new tranny any ideas? It is the 4.3l vortec v-6
4 sa10s
Taramps 8k
4 American Bass VFL 6.5s
Ohio Generator 305 amp alt
4 Vifa Tweets.
Old 07-15-2012, 11:14 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
pictures suck.
Old 07-15-2012, 11:59 PM
Humbled by CACO
0/11 sssss3111
no shit- pics of the body will help fix the tranny lmao. i found the truck i bought on a craigslist post and used there pics.
4 sa10s
Taramps 8k
4 Vifa Tweets.
Old 07-16-2012, 12:05 AM
duff_thrust's Avatar
0/11 ssssss629
If you back off of the gas on acceleration when it's ready to shift to second see if it will shift. If that ends up what it is I'd check into pricing out servos. Solenoids.
Old 07-16-2012, 12:08 AM
0/11 ssssss629
I drove a 95 ext cab short box with the 5.7 and auto tranny around for a while. It shifted through on the column fine as you accelled and only did it in second. But if you just tried to straight excell it would act almost like a stall trying to go into second. But if you backed off the gas a little bit it would work itself into second just couldn't do it at higher RPMs. Servo solenoids replaced and it shifted fine from there.
Old 07-16-2012, 12:13 AM
Humbled by CACO
0/11 sssss3111
absolutley exact same problem. Whats that entail? drop pan, check ohm load on the solenoids inside? or are there other ones i am unawre of? that is a extremly cheap part.
4 sa10s
Taramps 8k
4 Vifa Tweets.
Old 07-16-2012, 11:18 PM
18inchjeepin's Avatar
0/11 sssss1931
Feedback Score: 37 reviews
sounds like you kind of know your way around a tranny, do that 1st, yous guys have the same tranny
solenoids are no more than $50 a ea
Silver HHR
TEAM SOUNDSTREAM
XS Power D3100 with Toolmaker blocks
Alpine 9884-> Soundstream RUB4.600-> Soundstream SST-05 tweets-> Soundstream 804N 8" neo mids
A-pipe mini 1500-> pair Sundown SA15's -> 4th order wall
Cancelation issues in 02 Sonoma detroitdiesel Enclosure Discussion & Design Construction Help 5 11-14-2011 03:01 PM
1996 sonoma bagged Wanna-B-Basshead Miscellaneous Stuff For Sale 36 10-20-2010 06:25 PM
HU Problems big_way32 General Car Audio Discussion & Questions 3 09-23-2010 06:02 AM
Box request for sonoma sonoma Box Requests 0 07-30-2010 09:13 PM
