Frickin LEDs - Car Audio Classifieds!
Old 07-26-2012, 11:31 PM
Matt3824's Avatar
0/11 sssss3754
Default Frickin LEDs
I bought some wedge base LED bulbs to go in the map lights, and on this car, when the lights are on, the voltage is 12v, but when you turn them off, the voltage only drops to 8v instead of 0v like it should. So the lights go from bright(normal) to dim, which drains the battery. What can I do to fix this? I thought about a resistor but I'm not sure. I need help quick.
Old 07-26-2012, 11:38 PM
0/11 ssss31258
the LEDs are not the problem.
put regular bulbs back in and troubleshoot the system
Old 07-27-2012, 12:09 AM
Matt3824's Avatar
0/11 sssss3754
Why do you say that? It's factory lights. Why would there be an issue in the system? If going from 12v to 8v works with incandescent bulbs, there's no reason for the manufacturer to not use that system. This is a FORD by the way.
Old 07-27-2012, 01:36 PM
Matt3824's Avatar
0/11 sssss3754
Bump. Anyone else ?
Old 07-27-2012, 04:10 PM
0/11 sssss2429
Feedback Score: 46 reviews
Seems to be a common issue when replacing with leds.
Old 07-27-2012, 04:12 PM
Matt3824's Avatar
0/11 sssss3754
Ik. I need a solution.
Old 07-27-2012, 04:14 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
If it's not cutting the circuit unless they have some super fancy BS bulbs in there they will always be on.......
It's probably a fading circuit and it's not seeing the bulbs because they are LED and it's getting hung?
Team CACO Team SHOK
Supporting Member
Old 07-27-2012, 04:16 PM
HiloDB1's Avatar
0/11 sssss3158
There's your problem
LoL J/K
Old 07-27-2012, 04:19 PM
0/11 sssss2429
Try a resistor in parallel with the led,maybe a 1K.
Old 07-27-2012, 05:50 PM
Matt3824's Avatar
0/11 sssss3754
LoL J/K
Not my car. And yes I know. Chevy FTW.
Here's a wiring diagram I found for the whole overhead console assembly:
I thought about cutting the green/yellow to see what would happen but I'm afraid they wouldnt come on with the door open/close. Plus it's not my car so I don't want to start hacking stuff up.
This thread has a lot of information but I can't figure out how to put it to use.
http://www.moddedmustangs.com/forums...ome-light.html
So frickin tired of hearing.... Dj-DCSPL Off Topic Chat 2 07-29-2011 07:43 PM
LEDs Matt3824 General Automotive Chat 13 07-09-2011 11:14 PM
anybody done interior leds? SQLbeliever Off Topic Chat 25 10-26-2010 04:51 AM
Use relays for Leds? jprix82 General Automotive Chat 26 12-30-2009 01:05 AM
new HIDs/projectors/LEDs Snwbrdr1 General Automotive Chat 8 05-22-2009 01:08 AM
