Alt problem - Car Audio Classifieds!
Old 08-05-2012, 02:00 AM
hardrock2401's Avatar
0/11 ssssss219
Exclamation Alt problem
I just changed out the starter in my 97 grand am 2.4 which was an awesome time. Car starts up fine now but now my battery light is on, my front a rear battery is now barley charging over 12v. The day before I changed my starter both sat at 14.4 and 14.5 while on. Is there something I could of hit or somehow shorted a fuse maybe that is causing this.
Thanks
2004 Civic Si - K20a2/6spd swap, First gen Fi Q on a Twisted Sounds 1.3k
2015 Veloster turbo 6spd - stock daily driver
1986 Fiero GT - Pride and joy, awaiting a L67 swap
Old 08-05-2012, 03:06 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
Is it barely charging or not charging at all? If you're reading just over 12v at the battery, then you need a new battery.
Is there any wires you left off? Straight swap for the starter? Possibly your PCM/ECM doesn't like the new starter and isn't functioning because it thinks the starter isn't working.
Old 08-05-2012, 08:28 AM
0/11 ssssss219
Both batteries are fine, they sat at 12.8 with the car off before I did this. Now while the car is on both are barley charging over 12
Just went out and checked it this morning, the batteries sit at a higher voltage with the car off then when the car is on??
Old 08-05-2012, 10:54 PM
666WMD's Avatar
0/11 sssss1307
That's weird, sounds like a parasitic draw somewhere when the car is on. Try unhooking the batteries while the car is running and test the voltage. If the voltage changes then it might be a bad plate in one of the batteries. If it doesn't change, you may have a short somewhere that isn't fused.
DC Power Vortec V8 Dual Alt Bracket w/160 amp alt SundownSilverado Wiring, Electrical & Other Installation Equipment 5 07-13-2012 02:03 AM
problem with my new dc alt :[ Guerra213 General Car Audio Discussion & Questions 13 01-20-2012 08:37 PM
Problem with my MM Alt MikeyF General Car Audio Discussion & Questions 23 03-15-2011 01:53 AM
Unique dual alt PROBLEM, made a vid to watch!! NorthBeat General Car Audio Discussion & Questions 18 08-10-2010 09:01 PM
problem with 3kwp [Problem Solved] jizazz12 (Crescendo) 10 04-30-2010 06:46 AM
