Jackstands and a slanted driveway.. - Car Audio Classifieds!
Old 08-24-2012, 04:15 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
Default Jackstands and a slanted driveway..
I need to take my rims off but my driveway is at a slant and not flat. Now, I generally would never jack my car up on a slanted driveway but kind of assed out. Anyways, common sense says no way but I also think since I won't be under the car that it should be okay. Planning to do the one end at a time, that being the higher elevated side first. Take rims off for like an hour or 2. Put them back on, turn car around and repeat. I know to ebrake and put blocks behind wheels and all that good stuff. What do you guys think? Think it'll be okay?
Old 08-24-2012, 04:17 PM
0/11 sssss2011
Feedback Score: 61 reviews
is the driveway the only place on the planet that you can do this? if you move the car is it going to blow up? another driveway or a parking lot would be a better option.
Ricksi30's Avatar
0/11 ssssss997
How slanted? I've done it in my driveway that isn't flat, but it's not very slanted.
Head unit: Kenwood Excelon KDC-X996
Front stage: Alpine Type X mids Vifa Neo 1" silk tweeters
Component amp: PPI Bk800.4
Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
Sub amp: PPI Bk1300.1
Team SSA
Old 08-24-2012, 04:18 PM
0/11 sssss4519
My driveway is slanted as hell and I work on my truck all the time. A GOOD set of wheel chocks, but ive never had to take off more than two wheels at a time.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 08-24-2012, 04:19 PM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
In the middle of the street
Old 08-24-2012, 04:20 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Yes it is the only place on the planet I can do this, right now. My car won't blow up if I move it. Anyways, only other driveway is my cousins and his slants worse. Streets around my area are mostly at inclines besides main roads. I will not go to some random parking lot and leave my car on jackstands for a few hours at a time. I'm not ghetto like you.
Old 08-24-2012, 04:22 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
The driveway is probably like.. 20 degrees slant at most. I will be doing 2 at a time, fronts then rears.
Old 08-24-2012, 04:23 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
i do it in my slanted driveway all the time. man up if your call falls on you it wont even hurt, its an XB.
Old 08-24-2012, 04:25 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
terrible idea. do it right the first time. nothing better than just trying to switch your tires on a slanted driveway and a jack stand fails smashing you...
Old 08-24-2012, 04:28 PM
1/11 sssss2096
Good luck. Tell us how it went when finished.
Slanted aero enclosure design help Munkee Enclosure Discussion & Design Construction Help 5 03-29-2012 02:21 PM
Box build with slanted back DL Designz Build Logs 7 08-14-2011 12:03 AM
slanted baffle question... HeadAche Enclosure Discussion & Design Construction Help 17 03-04-2010 09:54 PM
Best way to remove oil spots on driveway? Patrick Simmons General Automotive Chat 18 11-22-2008 09:00 AM
