freaking electrical - Car Audio Classifieds!
Old 08-24-2012, 08:34 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
Default freaking electrical
i have been chasing down a small problem in my electrical system. symptom is when starting from a dead stop sometimes there is some hesitation and bucking(auto tranny) and sometimes when cruising there is an intermittant miss or something. check engine light does not flicker or come on. i hooked up the red snap on brick and no soft codes at all. so far i replaced and gapped the plugs,poured seafoam in the tank,changed the pcv valve. still not fixxed. bought a new front O2 sensor(brick showed it was a little lazy but working) and a coolant temp sensor. gonna install them tomorrow. also waiting on the new coils and ngk plug wires i ordered off ebay. if this doesn't work i am at a loss.
what else could it be?
My game is legit,
Old 08-25-2012, 03:10 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
Might not be an engine issue. Possibly the clutch plates are slipping then bouncing when engaging upon acceleration. Then the hesitation you fell occasionally while driving is the plates slipping a bit. A friend had a company car that did the same thing and the mechanics charged the company thousands to not fix the problem. It took an old timer mechanic to drive it and feel what was wrong, turned out the clutch plates in the auto were a bad compound. They would slip and bind then bounce when cold and occasionally slip when hot.
Old 08-25-2012, 03:35 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
and you are positive the tranny is fine (fluid topped off) and the torque converter is fine?
Sound like a mechanical issue to me
Current Build:
#60sHereIcome
Old 08-25-2012, 04:09 AM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
Sounds like a bad or dirty mafs (mass air flow sensor) you can get some cleaner at any parts store and see if it helps.
Sent from my MB870 using Tapatalk
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
The Slouich
0/11 sssssss94
It might be the soilenoid for you trany. A buddy of mine had sort of the same thing. One shop wanted to rebuild the trany. He took it for a 2nd op and they found a soilenoid sticking.
Old 08-25-2012, 08:38 AM
0/11 ssssss111
This. Wifey's 4Runner had exact same symptoms. After new O2 sensor, injector cleaning and tranny inspection I pulled and cleaned the MAFS. Runs like a top now.
Old 08-25-2012, 08:41 AM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
Sounds like torque converter to me..
Old 08-25-2012, 09:06 AM
4ozgloves's Avatar
0/11 ssssss309
That's exactly what I would recommend to try. I had the same issue with my lt1 car and the maf cleaning fixed it.
advanced electrical question on a/c electrical wire fatigue slowpoke General Car Audio Discussion & Questions 18 12-04-2011 02:40 AM
Freaking EPIC murderedtahoe Off Topic Chat 5 08-19-2010 11:28 PM
Electrical ? Bang This Beat General Car Audio Discussion & Questions 10 08-04-2010 07:09 PM
This guy on the reptile forum is freaking out. lulz. hornedfrog1985 Off Topic Chat 46 02-22-2010 06:34 PM
Freaking happy!!! bhhong General Car Audio Discussion & Questions 2 08-12-2009 03:53 PM
