Brake system suggestions - Car Audio Classifieds!
Old 09-17-2008, 12:05 PM
0/11 sssss9745
Default Brake system suggestions
Looking to replace my old brakes so I am thinking of going ahead and doing the whole braking system. I know of a few good ones but I wanted to see wht you guys think.
Old 09-17-2008, 12:18 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
I'm looking at the same thing right now.
I would love to get a Wilwood kit but I can't find one for our cars and the brembo front kit is $$$$$$$$
/ CAAA Member #2 /
Old 09-17-2008, 12:24 PM
0/11 sssss1123
Lincoln LS Accessories
Old 09-17-2008, 12:28 PM
0/11 sssss9745
I was looking at Brembo but still trying to decide. i would really love the Wilwood but I would have to take them of during the winter with all the snow from what I heard.
Old 09-17-2008, 12:30 PM
0/11 sssss9745
Originally Posted by SPL Guru View Post
My buddy owns that site and is a very good guy to work with. I may go with what he has if I can't find either one above for a good enough price.
0/11 sssss6075
I'm getting a wilwood set.
Also considering getting a 08 GT3 RS
Old 09-17-2008, 12:34 PM
0/11 sssss1123
Let’s look at some common rotor ‘modification’ and ‘performance’ upgrades that you may have been exposed to and try to separate the marketing from the engineering…
Super Sizing
Bigger rotors will make your friends think you are cool, bigger rotors look sexy, but bigger rotors do not stop the car. What a bigger rotor will do is lower the overall operating temperature of the brakes – which is a GREAT idea IF your temperatures are causing problems with other parts of the braking system. Take for example a F500 racecar – a small 800 pound single seat formula car. While the brakes are certainly much smaller than those found on a 3,000 pound GT1 Camaro, that does not necessarily mean that they need to be made larger. In fact, swapping on a GT1 brake package would probably do more harm than good – that’s a lot of steel hanging on the wheel that needs to accelerate each time the ‘go’ pedal is pushed. So, the motto of this story is bigger is better until your temperatures are under control. After that point, you are doing more harm than good…unless you really like the look (and hey – some of us do!).
Crossdrilling
Crossdrilling your rotors might look neat, but what is it really doing for you? Well, unless your car is using brake pads from the 40’s and 50’s, not a whole lot. Rotors were first ‘drilled’ because early brake pad materials gave off gasses when heated to racing temperatures – a process known as ‘gassing out’. These gasses then formed a thin layer between the brake pad face and the rotor, acting as a lubricant and effectively lowering the coefficient of friction. The holes were implemented to give the gasses ‘somewhere to go’. It was an effective solution, but today’s friction materials do not exhibit the same gassing out phenomenon as the early pads.
For this reason, the holes have carried over more as a design feature than a performance feature. Contrary to popular belief they don’t lower temperatures (in fact, by removing weight from the rotor, the temperatures can actually increase a little), they create stress risers allowing the rotor to crack sooner, and make a mess of brake pads – sort of like a cheese grater rubbing against them at every stop. (Want more evidence? Look at NASCAR or F1. You would think that if drilling holes in the rotor was the hot ticket, these teams would be doing it.)
The one glaring exception here is in the rare situation where the rotors are so oversized (look at any performance motorcycle or lighter formula car) that the rotors are drilled like Swiss cheese. While the issues of stress risers and brake pad wear are still present, drilling is used to reduce the mass of the parts in spite of these concerns. Remember – nothing comes for free. If these teams switched to non-drilled rotors, they would see lower operating temperatures and longer brake pad life – at the expense of higher weight. It’s all about trade-offs.
Slotting
Slotting rotors, on the other hand, might be a consideration if your sanctioning body allows for it. Cutting thin slots across the face of the rotor can actually help to clean the face of the brake pads over time, helping to reduce the ‘glazing’ often found during high-speed use which can lower the coefficient of friction. While there may still be a small concern over creating stress risers in the face of the rotor, if the slots are shallow and cut properly, the trade-off appears to be worth the risk. (Have you looked at a NASCAR rotor lately?)
Too cool!
Last year we bought 4 rotors. Two were bone stock, and two were subjected to a process know as Cryogenically Treating – one of the high-tech buzzwords floating around the paddock. The rotors were run back-to-back on the same track on the same car on the same day with temperatures taken to make sure that they saw the same level of heat. Following the track session, the parts were removed and we had them literally dissected by a materials lab.
The testing conducted included surface hardness, grain structure analysis, density, and surface scanning with an electron microscope. Guess what – after seeing the heat of use, the rotors looked identical in every regard. This is not to say that there is not a benefit from treating other parts which see lower temperatures and/or have different material properties, but treating our rotors on our car showed no tangible benefits (note that it didn’t seem to hurt anything either). Come to your own conclusions, but in our case, we’ll pass.
Summary
So, what’s the secret recipe? Again, there is no absolute right or wrong answer, but like most modifications, there are those which appear to be well-founded and those that ‘look cool.’ If ultimate thermal performance is your goal, look to what the top teams are running (relatively large, slotted rotors). However, if ‘image’ is your thing, break out the drillpress – and be prepared to replace your brake pads on a regular basis.
Old 09-17-2008, 12:41 PM
0/11 sssss6075
So whats the best upgrade?
Old 09-17-2008, 12:48 PM
SPY SPY is offline
0/11 ssss10192
Guru says - OEM is the way to go
lol
I agee though, most of the brake upgrades for our cars are useless for how we drive. That being said I still want a Wilwood kit
/ CAAA Member #2 /
Old 09-17-2008, 12:49 PM
0/11 sssss9745
Good post Guru. I wonder which is best too. I'm trying to find a good comparison of all the best available.
SUGGESTIONS for the amp and sub classified section aturcotte127317 Announcements - Suggestions - Feedback - Support 22 10-26-2008 12:59 PM
vehicle suggestions bones22 General Car Audio Discussion & Questions 30 10-21-2008 08:55 AM
need opinions/suggestions nismos14 General Automotive Chat 11 10-07-2008 10:04 AM
Decided to change up amps, suggestions? SPY General Car Audio Discussion & Questions 11 10-01-2008 09:05 PM
