Battery keeps getting drained. - Car Audio Classifieds!
Old 09-18-2012, 01:10 PM
JohnnyBoy's Avatar
0/11 ssssss128
Default Battery keeps getting drained.
When I was driving to work the car seemed to be running fine and I hadn't noticed anything out of the ordinary. When I got off and tried to start it, the crank sounded really sluggish and first thing that came to mind was a dead battery. I looked under the hood and saw that there was a considerable amount of corrosion on the negative. Anyways I sanded down the corrosion off the ring terminal and tried to start it again but no luck it didn't even crank just the starter clicking. So then I was thinking it was the alternator and didn't want to deal with so I had it towed home. I bought a Mike Singer alt awhile back and never got to installing it so I changed that. Well I had got everything in and I also changed the dead battery to one of the ones I had lying around in my room and the car started up but died a little later on and the battery light on the cluster turned on. Tried to start it up again but wouldn't start. Luckily I had more batteries I could use and test it out with a dmm. Hooked up another battery, car started and was at 12.26V, battery sitting was 12.54v with car off. It got as low as 11.28V and was gradually decreasing. All the other batteries had the same results, sitting voltage was acceptable but when the car started it would drop ~12.2V. Just trying to figure out what could be wrong and get back on the road. I've changed the battery, alt, serpentine belt and starter. Went on a vacation and came back and the battery sat at 3.70v. Was wondering how I could find the problem or what could be wrong.
HU - Clarion CZ702, Clarion EQS746
Frontstage - AQ4X90 & PPI P900.4/Mids: (2)6" Selenium 6W4P, (2)8" PRV Audio 8MB450, (2)10" DA PA255-8/Tweets: (2)Pyramid TW44/Midrange: (2)DA RS52AN-8
Sub build in progress - (2)Crescendo Audio BC2000D/(2)AA Mayhem 18s
Old 09-18-2012, 01:17 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
First off did you charge any of these batteries before installing? And second if you bump the gas does the voltage raise?
Old 09-18-2012, 01:23 PM
JohnnyBoy's Avatar
0/11 ssssss128
I charged one of the batteries full at my friends house then I started it and it did the same exact thing. No it doesn't raise voltage at all, revved it up to 2k rpms+.
Old 09-18-2012, 01:24 PM
1/11 sssss2095
sounds like the alternator is not charging the battery .
Old 09-18-2012, 01:27 PM
JohnnyBoy's Avatar
0/11 ssssss128
Had my stock alternator tested when I took it out and tested 3 times and it was fine. Singer alt failed 3 times, rectifier diodes were bad.
Old 09-18-2012, 01:37 PM
Supergumby5000's Avatar
0/11 ssssss642
Definitely a charging issue. You'll see 14+ volts if you're charging properly.
Get the car running, and check the voltage at the alternator. If its not 14+ volts, the alternator isnt doing its job. If it is 14+ volts and your batteries are only reading 12 volts, your alternator isnt installed properly.
Old 09-18-2012, 01:43 PM
JohnnyBoy's Avatar
0/11 ssssss128
Yea I know it would read 14+ if it was charging. But my stock alt wouldn't read 14+ and I didn't even mess with it, when I started my car with the Singer alt it did the exact same thing. What tells the alternator to turn on? The ignition?
Old 09-18-2012, 01:48 PM
0/11 ssssss642
Did you install your own alternator? If so, did you village-rig it in there or did you use a proper harness for your vehicle?
I've received harnesses with backwards plugs. Compare the harness for the singer alt to your stock harness and see if the pinouts match.
What vehicle is this in?
Old 09-18-2012, 01:53 PM
JohnnyBoy's Avatar
0/11 ssssss128
Yea it was only 2 bolts so I thought I might as well. I did it the proper way or I think I did haha. I mean I put it back on how I took it off lol.
The plug only went in one way cause the tabs prevented it from going on the opposite way.
97' Infiniti I30
Old 09-18-2012, 01:57 PM
garygross7's Avatar
0/11 ssssss305
Definite alternator problem. Awhile back my alternator was putting out good but it was getting to my battery I had blown my masterfuse. You should be able to crank the car then discount the ground off the battery and the car run on the alternator only. And my stock alternator does 14+
Battery Minder AGM Battery Charger w/ Desulfator andale927 Wiring, Electrical & Other Installation Equipment 8 07-26-2012 06:21 PM
WTB Battery Posts for kinetik battery MrRTJ24 Wanting to Buy (WTB) 4 06-08-2012 03:59 AM
Wiring battery bank from alt or front battery burzendowski General Car Audio Discussion & Questions 9 02-15-2012 04:36 PM
Will any battery charger charge a car audio battery ? laextreme5 General Car Audio Discussion & Questions 2 11-22-2011 10:39 AM
wtb small battery to replace oem battery sotelomichael Wanting to Buy (WTB) 2 09-01-2011 12:33 AM
