1998 Civic Lx coolant overflow problem? - Car Audio Classifieds!
Old 10-17-2012, 10:05 PM
03navi's Avatar
Feel The Bass!
0/11 sssss1505
Default 1998 Civic Lx coolant overflow problem?
ok i have this problem with my wifes honda the coolant is overflowing from the radiator
and the reservoir tank overflows as well like if all the coolant all goes into the tank .
and also the radiator cap and the bottom of the reservoir tank has this greyish gunk on it!
any suggestions?
1998 Civic Lx coolant overflow problem? - YouTube
"This next song goes out to everyone within a 3 block radius"
100% FeedBack on eBay
Old 10-17-2012, 10:09 PM
Mr.G6's Avatar
0/11 sssss4614
bleed the system mine did that and it was a air pocket
see the coolant inlet tube on the front of the motor carefully loosen that bleeder valve and when car is cool add fluid until it comes out the top
and do NOT tighten it down real tight it will strip so easily
if that doesnt work change the thermostat
2000 Gmc Sonoma ext cab
Old 10-17-2012, 10:15 PM
03navi's Avatar
Feel The Bass!
0/11 sssss1505
is there a vid of how to do this on youtube?
Old 10-17-2012, 10:18 PM
Mr.G6's Avatar
0/11 sssss4614
idk prolly not
dude its SUPPPPERRRR easy to do take a 12mm wrench loosen that valve about 3 turns
remove radiator cap and fill with antifreeze until it comes out the valve..
when it does tighten the valve and put cap on radiator
refill overflow tank if needed
0/11 ssssss340
ya, the level going up and down with the rpms would make me seem like it is due to an air pocket.
Old 10-17-2012, 10:29 PM
03navi's Avatar
Feel The Bass!
0/11 sssss1505
thanks guys! ill do that first thing in the morning!
Old 10-17-2012, 10:30 PM
Mr.G6's Avatar
0/11 sssss4614
does the bottom coolant hose get hot?
Old 10-17-2012, 10:37 PM
03navi's Avatar
Feel The Bass!
0/11 sssss1505
yeah sometimes but the top hoes gets really hot !
Old 10-17-2012, 10:38 PM
Mr.G6's Avatar
0/11 sssss4614
its supposed to be hot and so is the bottom one
if that bottom hose doesnt get hot u either have 1 massive air pocket
OR bad thermostat
Old 10-17-2012, 10:40 PM
03navi's Avatar
Feel The Bass!
0/11 sssss1505
well ill try to bleed the system first thing in the morning!
i appreciate this soo much!
Car running cold? Container for engine coolant(antifreeze)? its_ray_ray General Automotive Chat 13 08-28-2011 08:52 AM
Wtb exhaust can 1998 civic Nik592 Miscellaneous Stuff For Sale 10 06-04-2011 06:55 PM
Coolant being pushed into overflow... what did I do NorthBeat General Automotive Chat 17 01-11-2011 11:19 AM
Does anyone have a Honda civic or civic/si 2006-2010 or Audio_Prodigy General Car Audio Discussion & Questions 1 09-17-2010 11:37 AM
FS: Focus Coolant Tank Cover fasfocus00 Miscellaneous Stuff For Sale 0 10-04-2009 12:23 AM
