Oil light came on, went to pull over, car stalled - Car Audio Classifieds!
Old 10-18-2012, 09:17 AM
Anton Miller's Avatar
DoucheMiller
0/11 sssss3720
Default Oil light came on, went to pull over, car stalled
2000 cavalier z24
got about 160k on it.
so went ot sell my spare car. dude was going to buy it and we started driving it back to the cities form where it was (100 mile trip or so) and we got maybe 40 miles and the oil light came on, then sputtered, power loss, and then eventual stall (engine killed). opened hood and there was steam coming out, was a white smoke per say. we couldnt find any major leaks of anything, checked oil it was full according to the dipstick. so we tried ot start it again, it tried to starts, sputtered kinda made what sounded like a clunk or tick and didnt start. so we pushed it to a safe part of the p[arking lot we parked at. and tried to start it again, this time it fired, sputtered then killed.
so to recap.
40 mile trip
Oil light came on
loss of power
stalled
wont start back up
so my dads going to get it now in the morning and hes goign to look at it. few things we thought it could be was the catalytic converter or the Crank position sensor. but idk if either of those would make the oil light come on? and make it smoke? im just confused anyhelp will be appreciated....
1997 CHEVY CAVALIER - BUILT FOR EFFICIENCY!! YOUTUBE:
Old 10-18-2012, 09:20 AM
SacTownBully84's Avatar
0/11 sssss3682
Feedback Score: 51 reviews
oil pump? idk lol
98 Taurus
: CRESCENDO : AT : SKAR : MEMPHIS :
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 10-18-2012, 09:23 AM
DoucheMiller
0/11 sssss3720
another detail. car was running normal temp. then after shutting it off the temp rose to about 215 or so form 190ish
209native's Avatar
0/11 sssss1975
how was the engine temp ? did it overheat? did you check a to see if there was oil in your water or vise versa?
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 10-18-2012, 09:24 AM
0/11 ssssss816
Feedback Score: 22 reviews
A plugged converter would cause a severe loss in power, and would only cause the car not to start if it were entirely plugged, which I doubt happened that quickly, a crank sensor to my knowledge is only used along with a cam position sensor in most cars for start up, and referencing the no.1 cylinder, so even if it failed it shouldn't cause the car to stall, but not 100% on that for a cavalier. what were your engine temps like when this happened? any hotter than normal?
Old 10-18-2012, 09:25 AM
0/11 sssss3682
im no mechanic but the 1st thing i thought was oil pump.....if its mechanical and inside stopped pumpin....no oil would leak but it wouldnt move to cool off?...and would cause more friction, interms more heat?.....idk
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 10-18-2012, 09:26 AM
Mr.G6's Avatar
0/11 sssss4614
99% chance the oil pump failed..
if i was a plugged up converter the car would run like shit,.,.have no power at all
the converter itsself would be red hot and it would smell like rotten eggs..
the GM quad 4 (2.4) were widly known for bad heads and cheap oilpumps
ive owned 3 quad 4s and neither of them lived past 150k lol ive seen a couple 2.4s with 200k plus but they always had routine work done
2000 Gmc Sonoma ext cab
0/11 sssss3682
take it too a shop too many variables
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 10-18-2012, 09:27 AM
0/11 ssssss816
My assumption also would be head gasket or oil pump.
Old 10-18-2012, 09:28 AM
0/11 sssss3682
Originally Posted by SacTownBully84 View Post
oil pump? idk lol
i think this guy^^^ got it....lmao
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Push pull for VVX's? Sanders0492 Enclosure Discussion & Design Construction Help 7 07-24-2012 10:59 AM
how many amps does the 3500d pull at 1 ohm,at 14.4? felskee (Crescendo) 4 07-07-2011 06:50 AM
will i be able to pull a hairtrick easy? snoopysnooper Off Topic Chat 34 03-01-2011 11:18 AM
[SOLD]LiteGlow "Light Dancer" Musical Light Controller toolguy420 Wiring, Electrical & Other Installation Equipment 5 09-02-2009 02:12 PM
Oil for Booty: Federal oil lease employees had sex with industry reps Patrick Simmons Off Topic Chat 1 09-11-2008 01:05 PM
