Low voltage at idle!! - Car Audio Classifieds!
Old 12-12-2012, 10:29 PM
g6ryder's Avatar
WooferWarehouse.com
0/11 sssss2274
Default Low voltage at idle!!
Alright guys I have a Pontiac G6 '06. Electrical consists of Tenny's Alt 250 amp alt, Red Top Optima up front, C&D 100AH in trunk, Big 3. Now I idle very low! 11.8-12v, however at about 1500-2000rpms I'm back up to 14.5-14.8 instantly. I've tried just about everything. I've gotten a tune up, just installed brand new battery cables. Iirc the low idle still existed before the alt change. Red Top is maybe 2-3 years old, I bought it brand new. Alt is still very new 6 months or so.
Old 12-12-2012, 10:37 PM
0/11 sssssss38
Are you throwing any codes? Low idle can be caused by lots of things.
Old 12-12-2012, 10:38 PM
g6ryder's Avatar
WooferWarehouse.com
0/11 sssss2274
I'm no mechanic lol, I have no check engine light on or, service battery light or anything of the sorts..
Old 12-12-2012, 10:45 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
so what does the tachometer say you're idling at?
Old 12-12-2012, 10:49 PM
g6ryder's Avatar
WooferWarehouse.com
0/11 sssss2274
Well I have a Cobra radar detector, that's made for the IPhone so it has an app that monitors all my cars "vitals". Voltage, speed, direction, ect. It says I idle at around 11.9v. I've also tested it from the front battery by hand via a Milwaukee Clamp meter. No voltage readers inside the car itself
0/11 sssssss38
Iirc, low idle can be caused by a vacuum line leak, worn out cap and rotor, idle sensor can be bad (if throttle body is electric), egr valve can be bad, dirty injectors, etc.
Old 12-12-2012, 10:50 PM
0/11 sssssss38
He meant what rpms are you idling at, not the voltage to which you are idling with.
Old 12-12-2012, 10:51 PM
lileddie1127's Avatar
0/11 sssss1225
That's with your music playing? Install your stock alt and see if your problem persist. If your idle is rough, clean your throttle body and IAC.
6th order coming soon!
Team Juggernauts
Old 12-12-2012, 10:52 PM
g6ryder's Avatar
WooferWarehouse.com
0/11 sssss2274
I idle at about 1000rpms
Old 12-12-2012, 10:53 PM
g6ryder's Avatar
WooferWarehouse.com
0/11 sssss2274
No idle isn't rough, rather smooth actually. Nothing is playing, nothing even hooked up.
Tell me what causes voltage drop at idle Boomintahoe General Car Audio Discussion & Questions 18 12-03-2012 08:33 PM
ho alt question. very low idle assassin1840 General Car Audio Discussion & Questions 38 08-28-2012 04:42 AM
Voltage Drop at idle jonree4483 General Car Audio Discussion & Questions 17 03-04-2012 08:54 AM
idle voltage problems with 6g alt MERQUE General Car Audio Discussion & Questions 17 02-27-2012 01:27 PM
changing idle voltage on alt 9515ROB General Car Audio Discussion & Questions 1 10-11-2010 10:55 AM
