checking alternator - Car Audio Classifieds!
Old 12-13-2012, 03:04 PM
SPLpizzaguy's Avatar
Humbled by CACO
0/11 sssss3111
Feedback Score: 57 reviews
Default checking alternator
any way to check it with a dmm?? not taking it to autobone and let them even touch my shit.
+/- on the alt while running should work right. this is what i get for raping a stock batt and alt for so long.
4 sa10s
Taramps 8k
4 American Bass VFL 6.5s
Ohio Generator 305 amp alt
4 Vifa Tweets.
Old 12-13-2012, 03:08 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
just check your DCV.
its its below 13 with the motor on your alt is hurtin... most of the time.
The Following User Says Thank You to profundus-sanus For This Useful Post:
SPLpizzaguy (12-14-2012)
Old 12-13-2012, 03:25 PM
Mr.G6's Avatar
0/11 sssss4614
to actually test the amperage its putting out
you need a clamp meter that reads DC AMPS
most only read ac amps n volts not dc amps
seen a cheap clamp meter that reads dc amps on ebay for like 55bux
2000 Gmc Sonoma ext cab
The Following User Says Thank You to Mr.G6 For This Useful Post:
Old 12-14-2012, 09:23 PM
Humbled by CACO
0/11 sssss3111
was on delivery and car shuts putters out at 55 MPH get it pulled over and nothing. Just put in a BN yellowtop yesterday. definatly going with the alt.
thanks for your replies guys.
4 sa10s
Taramps 8k
4 Vifa Tweets.
Old 12-14-2012, 10:09 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
You need a way to put a load on the elec system and then clamp the + cable for DC amps.
Personally I'd take it to a parts store. It's the easiest.
Team CACO Team SHOK
Supporting Member
Old 12-15-2012, 02:16 AM
skinnyg's Avatar
0/11 ssssss828
autozone aint gonna hurt it, all they do is put 2 clamps on the pos and neg, then the clamp, when they tell you to turn on all your lights etc. (to put a load on it) see if theyll let you crank they system to add more load, they cant hurt it
Old 12-15-2012, 06:39 PM
Veteran Member
0/11 sssss3026
you don't have to put a load on an alternator to test it.
if the voltage is too low with just the voltage of your vehicle there is somethign wrong with it.
if you're trying to find out what your max amperage output is, then you need a load/ clamp meter... but it sounds like your more concerned with if its doing anything at all.
Old 12-15-2012, 06:50 PM
Austin175's Avatar
0/11 sssss4224
I'm in the same boat man here lately when I have been going to a full stop my car bogs down like it's about to die an the voltage meter drops really low.
I have a singer volt meter I need to put in tho so I can see what my voltage really is cause I don't trust my meter in my car an I have a 250 amp singer alt.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 12-15-2012, 06:55 PM
nelson1's Avatar
Awaiting Confirmation
0/11 ssssss735
To test if its charging just put the multimeter on volts dc and put it on the battery. Turn the car on and see if the voltage goes from 12+ to 14+. You should hear the alternator kick on with any kind of load.
Old 12-15-2012, 07:27 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Not all alts put out 14+
If you're over 13.4ish you're good.
Team CACO Team SHOK
Supporting Member
The Following User Says Thank You to 92K1500 For This Useful Post:
nelson1 (12-19-2012)
checking my ohms blkmrideon22s General Car Audio Discussion & Questions 2 02-06-2012 05:46 PM
Vancouver BC checking in Negafen New Member Orientation 1 06-03-2011 05:04 PM
checking in from Va jeepshaker New Member Orientation 13 11-29-2010 01:46 AM
checking PMs? thisistiny Announcements - Suggestions - Feedback - Support 3 06-08-2010 04:25 PM
Checking in sans pants New Member Orientation 7 11-06-2009 01:15 AM
