checking fuel pump - Car Audio Classifieds!
Old 12-16-2012, 02:06 PM
SPLpizzaguy's Avatar
Humbled by CACO
0/11 sssss3111
Feedback Score: 57 reviews
Default checking fuel pump
I have a working batt and alt now, i do not, however, have fuel in my lines. i do not hear the fuel pump start up either. what can i do to check the fuel pump before i drop the tank and remove it?
4 sa10s
Taramps 8k
4 American Bass VFL 6.5s
Ohio Generator 305 amp alt
4 Vifa Tweets.
Old 12-16-2012, 02:43 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
check fuses,relays, and inertia switch if it applys or trace the wire to the fuel pump find a easy spot and use a DMM to see if your getting voltage to the pump. If you had voltage troubles before the old batt and alt pump may be fried
Old 12-16-2012, 03:35 PM
Mr.G6's Avatar
0/11 sssss4614
check fuses
and u should be able to hear the fuel pump kick on when you turn the key on
every car ive had can hear the pump when 1st comes on
also 90% of cars u dont need to drop the tank the access point is under the back seat
2000 Gmc Sonoma ext cab
Old 12-16-2012, 06:31 PM
0/11 ssssss185
lol at 90% comment. thats very untrue.
The Following User Says Thank You to 2Loud4You For This Useful Post:
SPLpizzaguy (12-16-2012)
Old 12-16-2012, 06:33 PM
Mr.G6's Avatar
0/11 sssss4614
really? bc neons, cavaliers, sunfires, g6's
grand am's and the list goes on forever they all have fuel pump access panel under the seat
Old 12-16-2012, 09:32 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
My Escape does also
Sent from my DROID RAZR using Xparent Blue Tapatalk 2
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 12-16-2012, 09:34 PM
Eric B's Avatar
LowBlowBro
0/11 sssss2140
I haven't seen them in a GM vehicle. I have in Fords, though.
Old 12-16-2012, 09:35 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
has vehicle been in an accident? maybe pump needs to be reset.
My game is legit,
Old 12-16-2012, 09:55 PM
Raptor660's Avatar
0/11 sssss5243
Yea ford makes no sense! They do a good thing by adding a access panel to the fuel pump so u dont have to drop the tank but then they make a simple job like replacing an alt on my Escape V6 4wd nearly impossible (alt is on the bottom of the motor between motor and firewall and ur suppose to pull the cv shaft to replace it, took me 7hrs to put my Tenney 270 in)
And u had to undo the motor mounts and tilt the motor on my dads old Expo to change the rear sparkplugs
2005 Buick LaCrosse
Old 12-16-2012, 10:19 PM
Humbled by CACO
0/11 sssss3111
check fuses
not under the backseat/ haynes told me that part
4 sa10s
Taramps 8k
4 Vifa Tweets.
Replacing fuel pump? its_ray_ray General Automotive Chat 12 04-12-2011 04:25 AM
frozen fuel line? BeAlLsTaR13 General Automotive Chat 65 12-28-2010 10:44 PM
sump pump backup system mig139 Off Topic Chat 0 07-28-2010 04:43 PM
Nitro methane RC fuel? mattintc10 Wanting to Buy (WTB) 0 07-08-2010 02:01 PM
[TRADED]f/s, aeromotive 16302 fuel pump controller Nudels Miscellaneous Stuff For Sale 4 10-06-2009 11:59 AM
