help with tahoe engine - Car Audio Classifieds!
Old 02-08-2013, 02:14 AM
916slapin's Avatar
0/11 ssssss825
Default help with tahoe engine
I have a 2001 chevy tahoe 5.3 and I took it to get an oil change drove home and everything was fine the truck sat for 2 days. I go to start it and the gauge on the dash says no oil pressure and it started making a extremely loud knocking sound, so I turned it off any ideas what it could be.
Old 02-08-2013, 02:21 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Did you check the oil level yet?
Sounds like they didn't get the plug or filter tight and it drained the oil out.
Team CACO Team SHOK
Supporting Member
Old 02-08-2013, 02:23 AM
916slapin's Avatar
0/11 ssssss825
oil level was fine when I checked ill check again tomorrow and see if it dropped
Old 02-08-2013, 02:27 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
So the story is this:
Had oil changed
Drove home
Sat 2 days
Oil level is full
No oil pressure + knocking sound
Correct?
I'd call the people that did the oil change and have them tow it back to their shop to inspect it. Being that something is already knocking sounds like yer engine is toast due to lack of oil.
Possibly a collapsed oil filter. Did your oil pressure gauge read normal on the drive home?
Team CACO Team SHOK
Supporting Member
Old 02-08-2013, 02:31 AM
916slapin's Avatar
0/11 ssssss825
Had oil changed
Drove home
Sat 2 days
Oil level is full
Correct?
correct and oil pressure was fine on drive home I would rather try and fix it if I can to save time and hassel
Correct and oil pressure was fine on drive home I would rather fix it than have to go thru the hassel of going thru the shop
Old 02-08-2013, 02:48 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
It's fixable. It sounds like you have a rod knocking probably due to a spun bearing.
But before fixing the knock you gotta figure out why you have no oil pressure. Something on the pick up tube screen, plugged/collapsed filter, too thin of oil, bad oil pump etc...
There are just so many variables that it could be it's hard to diagnose on such limited information without being there to see/hear it.
Team CACO Team SHOK
Supporting Member
Old 02-08-2013, 02:50 AM
916slapin's Avatar
0/11 ssssss825
its got 140,xxx miles what oil should I be running and ill replace the filter see if that does anything
Old 02-08-2013, 03:01 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
The oil of choice depends on climate. GM generally recommends 5-30. If you live in a really hot climate I'd run 10-30.
Team CACO Team SHOK
Supporting Member
Old 02-08-2013, 03:15 AM
916slapin's Avatar
0/11 ssssss825
about 60 should be warming up though
Old 02-08-2013, 03:23 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
North Cali doesn't really have any extreme temps AFAIK. I'd just run the 5-30 that GM suggests. Should say it right on the fill cap.
Team CACO Team SHOK
Supporting Member
97 Tahoe crushing cans noise from engine area! 03navi General Automotive Chat 0 03-20-2012 06:54 PM
What engine to drop in? Dunbar91 General Automotive Chat 7 03-20-2012 02:14 PM
engine noise. JusRsounds Sound Quality Area 4 05-09-2010 01:46 AM
Engine Designer terra General Automotive Chat 123 02-11-2010 01:45 AM
Check engine Bushj311 General Automotive Chat 57 10-02-2009 02:12 PM
