Battery light with H/o Alt - Car Audio Classifieds!
Old 02-25-2013, 04:00 PM
SPLpizzaguy's Avatar
Humbled by CACO
0/11 sssss3111
Feedback Score: 57 reviews
Default Battery light with H/o Alt
I hooked up my 275 amp alt. The battery light came on, put a voltmeter to the battery it read -14.8 volts. Went from alt positive, to the chassis of the alt also reads -14.8..... Any ideas
thats negative 14.8 volts.
4 sa10s
Taramps 8k
4 American Bass VFL 6.5s
Ohio Generator 305 amp alt
4 Vifa Tweets.
Old 02-25-2013, 04:03 PM
younggunzbass01's Avatar
0/11 sssss1653
is it plugged in?
Ginger Filternator Impala Wagon pt. 2
12 12's
10k
Build log here
Old 02-25-2013, 04:17 PM
Humbled by CACO
0/11 sssss3111
I can't believe i walked out there to check, but yes it is.
it's the -14.8 volts on the battery i don't get. it's a brand new optima yellowtop been in the car and working fine for the 2 weeks its been in use before the new alt.
4 sa10s
Taramps 8k
4 Vifa Tweets.
Old 02-25-2013, 04:23 PM
0/11 ssssss337
Sounds like your plug could be flipped around.
Your batt is showing -14.v? Check the ground of the alt?
This is weird... you didnt series wire a batt did u?
We got two bodies in the morgue that look like they were
"serial crushed by some huge friggin' guy!"
Old 02-25-2013, 04:25 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
mine was on for a year n a half when i had my ho alt. normally you need some special plug to fix it. would have cost me like 25 bucks from dcpower at the time. as long as its charging still its not an issue, unless the bothers you, then get the right plug.
Old 02-25-2013, 04:40 PM
0/11 sssssss65
Is the belt ran the wrong direction around the pulley?
0/11 sssssss65
Actually, i don't even know if it matter what direction the alternator spins. it was just a thought.
Old 02-25-2013, 04:43 PM
0/11 sssssss13
My Dc 270 does the same thing in my blazer, but it still works so i think its alright lol
Old 02-25-2013, 04:56 PM
Humbled by CACO
0/11 sssss3111
There is only one positive wire going to alt...
Only a one battery setup until i get the box. all i am waiting on right now to get muzak.
4 sa10s
Taramps 8k
4 Vifa Tweets.
Old 02-25-2013, 04:57 PM
Humbled by CACO
0/11 sssss3111
Was told it may have the polarity backwards on the alt. Also he said if it was getting no volts as in the negative 14.8 it would not start. it starts, so thats a plus.
4 sa10s
Taramps 8k
4 Vifa Tweets.
Battery Light xnewbx General Car Audio Discussion & Questions 1 02-12-2013 12:42 PM
Wiring battery bank from alt or front battery burzendowski General Car Audio Discussion & Questions 9 02-15-2012 04:36 PM
Bypass charge light on dash with new alt?? oxsign General Car Audio Discussion & Questions 8 07-31-2010 07:55 PM
Battery light turned on. Ronin General Car Audio Discussion & Questions 8 10-06-2009 10:26 PM
