Popping sound while turning Jeep Cherokee - Car Audio Classifieds!
Old 03-17-2013, 05:36 PM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
Feedback Score: 38 reviews
Default Popping sound while turning Jeep Cherokee
Just noticed this yesterday while driving.I drive a 4x4 2000 Jeep Cherokee(xj). When I turn the wheel I hear a loud popping from the front end. It does it even louder when in 4wd. I checked the front drive shaft and the u joints seem good. Tie rod ends arent loose and the axle u joints dont seem bad either. Im guessing my wheel bearings are completely shot. Still have to get it jacked up so I can get a better look at stuff. Dont have a garage and my back yard is pretty muddy right now.. Anybody got any ideas? I dont want to drive like this and risk a wheel falling off or something worse happening. lmk Thanks
refs:
Old 03-17-2013, 05:38 PM
ispector's Avatar
0/11 ssssss376
Ball joints
The Following User Says Thank You to ispector For This Useful Post:
joe*89 (03-17-2013)
Old 03-17-2013, 06:38 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
I'm hoping you weren't turning in 4wd on dry pavement......
Team CACO Team SHOK
Supporting Member
Old 03-17-2013, 06:40 PM
*****, I like hopping.
Old 03-17-2013, 07:12 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
It's most likely ball joints, tie rods, or a front CV, in that order.lol. Wheel bearing would be like a drone or humming noise you'd probably notice most at lower speeds.
-Youtube Channel
The Following User Says Thank You to taylorpro For This Useful Post:
joe*89 (03-17-2013)
Old 03-17-2013, 08:20 PM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
nope, happened after out mudding. Was only in 4wd in the deep chit
Noticed it when I got back in town while turning, back in rear wheel drive.
refs:
Old 03-17-2013, 08:21 PM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
Thanks ppl, Im gonna have to investigate the ball joints. Looks like they run $25 bucks per upper and lower.
refs:
Old 03-20-2013, 03:16 PM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
Well, Finally got it jacked up and got it narrowed down. I checked the drivers side front first and its good. When the tires are off the ground, I can spin the passenger side front tire and I hear the grinding/popping sound. I checked for play in the tire first to see if the ball joints were shot and they are not. It does it worse when spinning the wheel and turning at the same time. Im pretty sure the wheel hub bearing is shot and possibly needs a new axle u joint.
refs:
Old 03-23-2013, 08:13 PM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
Welp.. Just got done messing with it today since it was nice outside. I figured out exactly what is the prob. Its the passenger side axle u joint. Almost all the needle bearings in the top cap are gone. I turned the wheel to the right, got under it and gave it wiggle right at the u joint and a couple bearings fell right out. :O
refs:
Tags
its a jeep thing...
jeep cherokee xj Wanna-B-Basshead Member Rides & System Pictures 12 06-08-2013 10:33 AM
340 Amp Mechman alternator for jeep grand cherokee 6.1L or 5.7L jeep commander Mnorwood01 Wiring, Electrical & Other Installation Equipment 16 12-29-2012 10:09 PM
Anybody done any before & after testing of sound deadening a jeep grand cherokee Mnorwood01 General Car Audio Discussion & Questions 1 12-15-2012 04:00 PM
88 jeep cherokee??? jare_ball General Car Audio Discussion & Questions 16 08-02-2009 09:04 PM
