civic hatch issues - Car Audio Classifieds!
Old 03-22-2013, 04:02 PM
Default civic hatch issues
I have a 1989 civic hatch with the "awesome" 1.6 sohc motor.
It usually fires right up if you leave it sitting for a while and the motor is cool, but after it warms up it stalls out easy and then will not restart, it will crank and has plenty of fuel but won't fire?
Old 03-22-2013, 04:05 PM
oh I should say it has fuel up to the motor but won't fire until you crank, sometimes for 10-200 minutes. It will also stumble when cranking and half start then die off again. Car has a light weight flywheel but that's only mod.
Old 03-22-2013, 04:06 PM
0/11 sssssss38
Just a swing in the dark here, do they have egr valves? I guess it would throw a cel if it did...
Old 03-22-2013, 04:07 PM
not sure, I just remember it does have a co2 sensor just plugging the hole some one cut the wires a long time ago.
Old 03-23-2013, 10:55 AM
So I'm guessing I'm not the only one confused?
Old 03-23-2013, 01:18 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Check the coil/coil pack as soon as it dies see if it still fires my nephews car was doing the same and when the coil got hot it would quit firing.
Fuel,fire and air is all it needs to run, if it is still getting a spark try a small shot of starting fluid and see if it will bust off again, if it does may be a problem in fuel delivery.
Old 03-23-2013, 02:11 PM
Mr.G6's Avatar
0/11 sssss4614
that "awesome" motor you have if its a 1.6 is a mini me swap..because that car sure didnt come with it from factory thats a d16z6 or d16a2 sometimes you see a d16y7 but those were in the newer civics
those motors are proven to be bullitproof..you cant kill them ( my 1.5 d15b7 has over 245k and runs like a top)
as for your no sparking issue
pull the distributor take those 3 bolts that hold it in and see if the contacts r bad etc..
and replace it
2000 Gmc Sonoma ext cab
Old 03-23-2013, 02:35 PM
I'll check the coil, and that was a typo 1.5 not 1.6.
this car has been driven hard that's for sure. it still runs and drives pretty well other then this issue.
Old 03-23-2013, 02:39 PM
Mr.G6's Avatar
0/11 sssss4614
whats the engine tag on the fron tof the block say its a up raised square below the top radiator hose
i bet its either a d15b5 or b7
Old 03-23-2013, 03:02 PM
I'll go look later, all I remember it was from canada.
wtb HO alt for a 91 civic 1.5l hatch xxxbasshead Wanting to Buy (WTB) 2 09-28-2012 05:21 PM
recommendations for my civic hatch. acid0atm3al New Member Orientation 1 09-24-2012 08:20 AM
91 civic hatch jackdaniels General Automotive Chat 18 08-30-2011 02:00 PM
91 civic hatch thread sleepingciv Build Logs 88 03-31-2011 09:11 PM
My Nephews 94 Civic Hatch teamsubgopoof Build Logs 10 12-15-2008 09:27 AM
