Chevy help. - Car Audio Classifieds!
Old 05-12-2013, 11:24 PM
0/11 sssss1184
Default Chevy help.
Hey guys, I need some help with my truck. I figured I woul ask here before bringing it in to a shop.
Vehicle: 97 s10 single. 2.2 5 speed.
Just recently, it's been starting a lil rough. Takes a couple times before it turns over. It will drive pretty "boggy" in first and second for 1-2 minutes then drive normal after that. It has me concerned.
Where can I start?
I'm no "grease monkey". Any help is greatly appreciated.
Boughten from:
Jäger, $lick Califa$, it's a Jeep Thing, Bsteinb, vitveet, Slamminhos, Jbizzle, Loganberry, Itru50racer690
Old 05-12-2013, 11:44 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Leads me to believe its cap or rotor or wires plugs (or all) ...usually cap rotor... when the motors hot, the less spark can be assisted by the hot motor to help with combustion... id try a cap and rotor first
Old 05-13-2013, 07:52 AM
0/11 ssssss214
Give it a tune up. Plugs, wires, oil, seafoam treatment. Not really running good after that then I would troubleshoot a little more in depth. I'm sure you could use a good tuneup.
Think your own coil packs and not a distributor....
Sent from Rezound using Tapatalk 2
Old 05-13-2013, 12:01 PM
0/11 ssssss214
Also clean ait filter or replace, clean your mass air flow sensor, and throttle body plate while your at it.
(6) SA-8 v1 finished in my chevy Bsktbll895 (Sundown Audio) 16 12-01-2011 03:10 PM
91' Chevy Z-24 3.1 V6 zlibby76 General Car Audio Discussion & Questions 0 03-09-2011 12:05 PM
Old Chevy Build Ryan1126 Build Logs 1 04-25-2010 01:31 PM
chevy race pistons. chevy small block Violence* Miscellaneous Stuff For Sale 5 01-27-2010 12:52 AM
My Chevy STR8BLaZiN Member Rides & System Pictures 15 01-01-2010 06:38 PM
