Anyone good with chain saw/go-ped/2stroke motors? - Car Audio Classifieds!
Old 06-17-2013, 02:34 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default Anyone good with chain saw/go-ped/2stroke motors?
I figure this is the best place for this. It's a long read, so bare with me..
I managed to clean my WT-40 carburetor and I got it running good for about 30 seconds.
Only tuned it initially to the recommended 1-1/2 for low jet and 1-1/4 for high jet and it was really fast and responsive.
Then it started to die out and sputtering like I was randomly hitting the kill switch, and finally stopped running altogether.
I changed the fuel filter out and that didn't help.
When I took the exit line from the carb off, it was only putting out a pure white/clear fluid. But then when I let the exit line drain into a cup I had, it started to turn green/blue (pre-mix)
The carb primer bulb is also showing a milky white liquid...
I can't tell if it's the fuel filter, or the carb. But it's happened with both carbs, and the barrel/stock carb I have runs fine on my other 230 motor.
BTW The motor is a case, cylinder and flywheel from a zenoah g230rc, the piston and ring is from a G23LH motor.
team graham
Old 06-17-2013, 03:56 AM
0/11 ssss31257
I expect you managed to get water or 'something' in your fuel. To fix it, you'll need to drain and rinse all the fuel out with clean gas (not mixed). Then replace the spark plug and put new mix fuel in.
unrelated: you should clean your air filter with filter fluid also.
{just pour the fluid on the clean side and work it through until all the dirt is gone.}
graham (06-17-2013)
WTB 2 good motors hardrock2401 Wanting to Buy (WTB) 9 09-03-2012 06:41 PM
AB VFL Motors any good?? RetroAudioInc General Car Audio Discussion & Questions 4 06-05-2010 08:52 AM
Wtt: Rd audio sonance 18" v.2 for gold chain dadydolas Car Audio Trader (WTT) 2 12-04-2009 11:04 PM
Skull/Ice Wallet Chain worstenemy453 Miscellaneous Stuff For Sale 0 02-26-2009 07:25 PM
AQ SD2.5's. 3 motors and 1 good sub. Naledge503 Speaker Accessories & Parts 4 01-10-2009 08:25 PM
