How would you repair this door panel? - Car Audio Classifieds!
Old 07-01-2013, 10:51 AM
0/11 sssss3842
Default How would you repair this door panel?
Vehicle is a 93 explorer. The top portion of the door panel is busted and cracked away from the rest. Any ideas on how to fix it? I did try a plastic welder but just couldn't get the hang of using it.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 07-01-2013, 10:57 AM
0/11 ssss31258
you could use a soldering iron to melt the hidden side of the crack.
one main melt in the crack, then melt 'stitches' across the crack.
[it appears someone already tried to]
fiberglass resin can work also. make sure to scuff the shiny surfaces so the resin has something to stick to.
916slapin's Avatar
0/11 ssssss825
This is what I have used to repair plastic things in my collision repair class if you use it right it will bond it very strong HSW-200 | Hot Staple Welder :: Pro Spot
The Following User Says Thank You to 916slapin For This Useful Post:
97_eldo (07-01-2013)
Old 07-01-2013, 11:01 AM
0/11 ssss31258
that's pretty neat.
{I'm out of thanks}
Old 07-01-2013, 11:06 AM
0/11 sssss3842
Yea I attempted using a plastic welder.
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 07-01-2013, 11:13 AM
0/11 ssss31258
my $51.29 craftsman soldering gun is better than a plastic welder.
Craftsman Professional Dual Heat Soldering Gun - Tools - Welding Equipment - Soldering Tools & Accessories
note: MaC Tools uses/sells the exact same soldering gun under their name.
Radioshack has decent soldering guns for $30ish also. {decent meaning they work well but don't last long}
Old 07-01-2013, 11:17 AM
916slapin's Avatar
0/11 ssssss825
that's pretty neat.
{I'm out of thanks}
That tool is amazing I'm gonna buy one, after you fix it with that you use 8115 adhesive on the inside of the door panel where u fixed it and it is so strong I love that tool
Old 07-01-2013, 08:24 PM
0/11 sssss3842
Picked up some "plastic bond epoxy". Well see how we'll it works
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 07-01-2013, 08:31 PM
if that doesn't work pl400 should and so will ca glue.
Old 07-01-2013, 09:28 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
Ca glue.wouldn't hold under the force opening and closing( I don't think)
But.you can ca glue.it straight and true then.fiberglass is your.best bet if you can't melt.it back together
Sent from my HTCEVOV4G
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
1999 Mustang door panel help??? jbattles General Car Audio Discussion & Questions 15 10-11-2012 09:55 AM
Styrofoam in Door Panel? EARmeBump General Car Audio Discussion & Questions 12 11-09-2011 11:09 AM
Door Panel request for d-monday d-monday Box Requests 2 10-20-2010 12:23 PM
Door Panel Design Help strpperpolef150 General Car Audio Discussion & Questions 9 02-17-2010 10:27 PM
My door panel build DeadlySones Build Logs 5 07-15-2009 09:42 PM
