2013 Honda ELD - Car Audio Classifieds!
Old 08-28-2013, 07:00 PM
0/11 ssssss201
Default 2013 Honda ELD
Anyone bypassed or unplugged the eld in a '13 civic or know someone who has? I unplugged mine in my 08 and everything was fine but now I have a '13 and haven't seen any info on if it's still ok.
Refs: Mitch86, talon, kramer_212, kushy_dreams, ctmaudi, pro-rabbit
Old 02-18-2014, 10:39 PM
0/11 ssssss201
Anyone?
Old 02-24-2014, 11:53 PM
0/11 ssssss226
honda ELD is to let it see a load and it will charge at 14.4/5V
blower motor speed two is what i do..no need to bypass it or add resistors..
The Following User Says Thank You to markc32 For This Useful Post:
walwalka (03-31-2014)
Old 08-23-2014, 10:02 AM
0/11 ssssssss5
Anyone find a bypass for the ELD yet?
The new accord is setup with the ELD (Electronic Load Detector) gathering data from the ECU and the engine to figure out when the alternator needs to increase the charging voltage (14.4-14.6) or run in standard, non-high output mode, (13.2-13.6). Not having the ELD bypassed from what I understand means that the amps are never seeing the full amount of power that they need, unless you are driving and the RPMS are past 2k. In the past model accords, people have been able to successfully bypass the ELD, but the new system is different.
Fire up the car with the A/C, rear defroster, lights, all being used. Watched the voltage drop to the 13's. With the bypass, you just hit the switch and the voltage goes back up to mid 14's.
2013 Honda ELD MANTI5 General Car Audio Discussion & Questions 2 08-28-2013 05:25 PM
Need some help! ELD Module ReaLBallA General Car Audio Discussion & Questions 4 04-22-2013 01:13 PM
2013 Tour De Classics Car & Motorcycle ~ Denver CO ~ 05-05-2013 CACO's Car Show Bot Car Show Feeds 0 03-18-2013 02:10 AM
need help on a few things dc alt honda civic eld bypass? Guerra213 General Car Audio Discussion & Questions 11 01-29-2012 08:41 AM
Honda ELD jason General Car Audio Discussion & Questions 7 07-28-2010 08:32 AM
