Fuses Popping - Car Audio Classifieds!
Old 08-30-2013, 02:37 PM
0/11 sssssss55
Default Fuses Popping
So I just installed 2 HID headlights w/ballasts and they will not turn on. Every attempt i make to turn them on I am popping the fuse. There was originally 1 15amp fuse for both lights, i jumped up to a 30amp fuse and this is popping as well. I have removed the daytime running light relay and checked the polarity of the connections. Anyone have insight on what the problem may be?
They are 35watt HID's in a 2005 Chevy Suburban 1500.
Old 08-30-2013, 02:40 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Might have a short somewhere...try with just one bulb at a time hooked up and see what happens
Ull likely need a relay as well, inrush current may be to much for ur fused stock circuit to take
Old 08-30-2013, 03:20 PM
0/11 sssssss55
Sounds about right. One side worked but once i started adding lights it never came back on.
Old 08-30-2013, 03:36 PM
Authorized Vendor
0/11 ssss14115
Get A relay for each side... get one that can handle the max ampere draw listed for the lights to be ran... the original headlight wires will be the activator for your relays and a new positive from the battery will feed the new lights through the relays circuit
Old 08-30-2013, 03:47 PM
0/11 sssssss55
Thanks
eq popping noise dcollister440 General Car Audio Discussion & Questions 5 02-27-2012 01:57 PM
Square fuses. small fuses w/smartglow SPLpizzaguy Wiring, Electrical & Other Installation Equipment 0 03-15-2011 10:20 AM
So my sub is popping?? BigC-Expo General Car Audio Discussion & Questions 12 08-01-2010 10:18 PM
3kwp popping ryder829 (Crescendo) 21 06-19-2010 12:46 PM
Popping in Speakers BassikInstincts General Car Audio Discussion & Questions 20 09-07-2009 09:49 AM
