truck wont start - Car Audio Classifieds!
Old 12-14-2013, 06:25 PM
Kcbme's Avatar
0/11 ssssss526
Default truck wont start
Hey everyone so I posted this problem on explorer forums and haven't found a fix yet and everyone on here has helped me with any questions so I figured maybe there are some auto guru's out there who can help me because I am stumped on this problem.
While driving my truck it would randomly shut off the engine and power steering but the electronics(radio, A/C, ect) would remain on(started about a month ago and got more frequent until it finally died, but it would usually start back up. Yesterday while driving home I lost all power and the rpm's spiked for about 3-5 seconds and the security light was blinking and then I regained power, it did this 2 times before it finally died. I was able to restart it once but it died about a 1000 yards later and would not start. I tried to jump it but that would not even work, when in aux mode the electronics are on but when I turn the key to start it all the electronics shut off and there is no noise. I charged the battery from 12.3 up to 12.7 and that made no difference. So I hooked up the battery charged to it and used the 50 amp engine start and that started it, but the truck would die after a few minutes of running at idle. I took the battery and alternator to get tested and they both are good. Any one know whats wrong? Thanks for taking the time to read this long story and any input is appreciated.
Vehicle is a 2002 ford explorer sport trac if it matters.
2001 suburban
2.8:1 4th
4 db drive wdx 7k 18s on 2 crossfire 8ks
Old 12-14-2013, 06:31 PM
cerwinvega_fan's Avatar
Loyal Member
0/11 sssss1788
Has it ever turned off while driving on the freeway?
Old 12-14-2013, 06:32 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
sounds like it may be the ecu or ecm
check all those fuses? any lights on
Old 12-14-2013, 06:35 PM
Kcbme's Avatar
0/11 ssssss526
No it usually has happened while going less than 45 mph and it did it a few times while doing up inclines like pulling into a store with an inclined driveway. The most recent time was on a major bridge right by my house but luckily it has a huge shoulder and I was able to get over but now I am scared its going to happen while turning in somewhere and loose my power steering and hit someone so until I can figure this out I am driving our good 'ol burb.
2001 suburban
2.8:1 4th
Loyal Member
0/11 sssss1788
Yea something similar happen to me and it was just a blown fuse under the hood.
Old 12-14-2013, 06:37 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Check all the grounds, any CEL's on?
My 92 F150 had a weird problem once where it would run perfect but when you turn the headlights on the passenger side light was dim, and the engine would shut off.
At first I couldn't figure out what it was because I hadn't turned the lights on with it running, it just wouldn't start when I already had them on. I finally realized when I turned the lights off I would hear the fuel pump fire up. Made the connection to that being the problem, started tracking wires to see why the bulb was dim and found I had an intermittent ground for it.
Then out of the corner of my eye I noticed the little bolt in the fender for the body ground wiggled as I was pulling on the harness. Tightened the bolt down and no more problems.
It's funny what the smallest ground problem can cause.
Team CACO Team SHOK
Supporting Member
The Following User Says Thank You to 92K1500 For This Useful Post:
Aero_d2 (12-20-2013)
Kcbme's Avatar
0/11 ssssss526
I checked a few fused a while ago but not all of them so I guess I will go through all the fuses tomorrow to be safe. No warning lights are on while running and I even had it plugged in the day before it died and there were no codes no lights no nothing
2001 suburban
2.8:1 4th
Old 12-14-2013, 06:38 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
You don't need power steering or power brakes to drive a vehicle
Team CACO Team SHOK
Supporting Member
Old 12-14-2013, 06:39 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
Fix
Or
Repair
Daily
Old 12-14-2013, 06:41 PM
sthrnbumpn's Avatar
0/11 sssss2961
try telling a woman that,
rebuilt top end, put distributor back in, suburban wont start. it back fires. kickerfanatic General Automotive Chat 7 09-01-2011 09:21 PM
alero problems. wont start? securty problem? snoopysnooper General Automotive Chat 32 04-26-2010 08:37 AM
