Can I use the empty slots in the fuse box? - Car Audio Classifieds!
Old 03-26-2014, 05:52 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default Can I use the empty slots in the fuse box?
I want to add a fuse to my cache cloc'd after the incident yesterday with the 2a fuse on the pac pclc21 popping.
I'm wondering if the fuse box under the dash (right next to the radio) is all wired up, and just needs an additional wire and fuse to go to another device.
I have no experience with fuse boxes and I don't want to take mine out to experiment in case it could cause major problems.
Here is a pic of the one in the cabin.
I assume there is a single 8 or 4awg wire coming in from the engine fuse box with a big 200a fuse or something.
Actually, now that I look at it, I know that thick red wire is going to the back, directly into the battery.
Are all those other wires where you would insert the leads coming from the fuses? (Like I said, no experience with fuse boxes..only in line fuses)
team graham
Old 03-26-2014, 06:09 PM
socalxj's Avatar
0/11 sssss2371
Sure but it's not as easy as you think unless you have an empty hot terminal for accessories. Take two female quick connect wire terminals and connect one to each side of the fuse. There you made your own fuse block!
I like that your always thinking Graham
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Looks like a nightmare of a job (like running wire through a Molex) and IIRC the empty slots don't usually have wire behind them, but most of my experience lies with imports, so GM could be diff.
Good luck, prob gonna need it!
Old 03-26-2014, 06:15 PM
doug118's Avatar
0/11 sssss4674
It is possible but that fuse box looks like a total PITA
Old 03-26-2014, 06:19 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
What do you mean by that? Like one that is already hooked up but doesn't have a fuse, as if I removed a fuse from something that is being used, etc?
I know I have several in line fuses. I wanted to make it real clean though. This seemed like a great way to clean my wires up, especially with my switches. I wanted to put a fuse on them too.
It was either this, or buying a small fuse block like this and placing it near the stock one.
New DC32V 6 Way Terminals Circuit Car Auto Blade Fuse Box Block Holder ATC ATO | eBay
team graham
Old 03-26-2014, 06:28 PM
socalxj's Avatar
0/11 sssss2371
Score yourself one of these...ATC and ATO 6 Ganged Fuse Block
Old 03-26-2014, 06:35 PM
0/11 ssssss292
Do you want a directechs printout for your car?
Old 03-26-2014, 06:52 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
Feedback Score: 22 reviews
you can certainly use those bud, thats why they are put there. however it is hard to wire up in the newer vehicles. take the dude above me up on his offer for those sheets, They will come in handy.
Old 03-26-2014, 07:03 PM
0/11 ssssss292
i do remote starts and installs for a living. You are better off using a different gameplan instead of trying to use the factory pinouts. not saying it cant be done, but id just work on wire management instead of what you are proposing.
my 2 cents
The Following User Says Thank You to Deegan2 For This Useful Post:
ltr450racer690 (03-26-2014)
Old 03-26-2014, 07:11 PM
ltr450racer690's Avatar
0/11 sssss3414
^^^^^^^^ that
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
Flared slots skinnyg General Car Audio Discussion & Questions 11 02-22-2013 10:10 AM
Battery terminal options, please help! no more room and I need more slots! graham General Car Audio Discussion & Questions 4 01-28-2013 08:55 PM
Empty Dual Bandpass Box $150!!! Raptor660 Craigslist Deals 6 02-15-2012 11:26 PM
Anyone Test Aero ports vs Rounded Slots? murderedtahoe General Car Audio Discussion & Questions 12 12-03-2011 10:53 AM
Empty computer case nitro_freak1 Miscellaneous Stuff For Sale 1 12-09-2008 10:29 PM
