need help relocation vaccum line - Car Audio Classifieds!
Old 07-05-2014, 11:12 PM
Kcbme's Avatar
0/11 ssssss526
Default need help relocation vaccum line
So here the deal I just purchased a singer 320 amp hairpin alternator and the charging stud comes off the back instead of the top of the alt so I need to re run a portion of a vaccum line in order to make it fit. My question is can that be done and what kind of hose do I use? It is the hard rubber corner piece that connects the two softer rubber hoses. It is a 4.0 sohc if matters. Here is a picture[IMG][/IMG]
2001 suburban
2.8:1 4th
4 db drive wdx 7k 18s on 2 crossfire 8ks
Old 07-05-2014, 11:30 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
You should be able to re route that line out of the way without any issues by running the soft line differently or replacing the hard line with soft line. Usually hard lines are used in areas that get lots of heat or oil buildup from a pcv valve or something of the sort. Any silicone line will work fine as long as you zip tie it in place and try to keep it from getting too close to the heads or manifolds. Valve covers and intake/plenum will not get hot enough under normal circumstances to damage it anyways.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
The Following 2 Users Say Thank You to e46inperrycounty For This Useful Post:
danny1mmafan (07-05-2014), Kcbme (07-06-2014)
Old 07-06-2014, 12:24 AM
Kcbme's Avatar
0/11 ssssss526
Alright thanks I will go to autozone tomorrow and see what kind of hoses they have and then find a safe place to relocate the hose.
2001 suburban
2.8:1 4th
WTB line output converter without a line driver built in. speaker inputs preferred graham Wanting to Buy (WTB) 1 04-20-2013 10:22 PM
Cache cloc'd line output/line driver questions. graham General Car Audio Discussion & Questions 8 02-24-2013 06:47 PM
strong vaccum pressure when i remove oil cap n a whining noise. help....... kickerfanatic General Automotive Chat 4 11-05-2011 09:51 AM
relocation tankglh21 Off Topic Chat 16 08-06-2009 01:38 AM
