Ok....I'm stumped - Car Audio Classifieds!
Old 08-09-2014, 07:13 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Default Ok....I'm stumped
My s10 blazer won't turn over w/o having to jump it 1st. Try to turn the key and voltmeter shows nothing. There's no click click click so guess that's a good sign. However, once I jump it, I let it run for about 10-15 mins in the driveway. thinking maybe the battery needs to be re-charged. Once it's done running for a little bit, I turn it off then turn the key again w/o starting it. And have some voltage. Here's the tricky part: Same day I did this, let it sat for several hours then went out to try and start it again. Nothing.
I turned the alt by hand...sounds good, no squeaks. So guessing the alt is still ok. Perhaps the battery I bought earlier before summertime isn't holding a charge??
Help/ideas/suggestions. (I'll take some voltage tests with my dmm in the afternoon and post up results.)
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 08-09-2014, 07:19 AM
Sounds like either a bad battery or loose connection somewhere. If the truck will run for 10-15 mins it's almost certain that the alternator is working correctly. Years ago when I drove an Eclipse I had the same problem and it ended up being a slightly loose neg. terminal on the battery. I've also seen issues where the fusible link between the alt and battery was kaput (don't know if you have one or not). Poking around with the DMM should give you the answer.
Old 08-09-2014, 07:24 AM
0/11 ssssss292
I just replaced the starter in my bosses truck with the same issue. Only to reinstall the original starter after finding the ground was corroded. Also not for nothing but are you sure the ignition switch is working correctly?
Old 08-09-2014, 08:55 AM
0/11 ssssss881
sounds like a loose battery connection like the other guy said..
The Following User Says Thank You to shriver187 For This Useful Post:
sthrnbumpn (08-09-2014)
Old 08-09-2014, 06:00 PM
0/11 ssss12531
8.06...just minutes ago.
Other day think I got 10.76 or so.
Just did some poking around and see some corrosion on the negbattery cable end to the starter. Gonna take that apart Monday see if that's it. Corrosion bad...= no good won't make good contact.
Checked for connection s as y'all suggested and are right.
Will keep this updated.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 08-09-2014, 06:20 PM
˙˙˙¿ʎzɐɹɔ noʎ ǝɹ∀
0/11 sssssss77
Sounds like a dead battery.
This happened in my ram 1500, I pulled up to a gas station, and in the time that I filled up the tank, the battery died completely. Had to get a jump and man I feel bad for the guys alternator that jumped me. I had to grip the cable ends into my posts and his van sounded like it was going to stall out starting my truck. Was all him, my battery was completely shot.
Old 08-09-2014, 07:04 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
If you are putting the jumper cables on the existing battery terminals and it starts fine, I would say that eliminates the possibility of loose connections and since your voltage is at 8 and 10v, pretty much self explanatory that it's the battery
team graham
Old 08-09-2014, 07:48 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
What is the alt charging at when its running?
Old 08-09-2014, 08:25 PM
4ozgloves's Avatar
0/11 ssssss309
Bad cell in the battery. I sell car parts for a living and see this stuff every day
Old 08-09-2014, 08:30 PM
SoCalBean420's Avatar
время решает все
0/11 sssss7110
Feedback Score: 42 reviews
battery going bad, loose wires or corroded ground wire is my guess. have had the same problems with my older vehicles
“We can ignore reality, but we cannot ignore the consequences of ignoring reality.”
― Ayn Rand
Stumped deciding between multiple component sets and pro audio sxpimpin General Car Audio Discussion & Questions 13 12-22-2012 09:14 AM
Question: Crossover and Wiring. Im stumped. Enigma311 General Car Audio Discussion & Questions 28 02-24-2012 04:55 PM
im stumped. need comedian help Memphistahoe02 Off Topic Chat 12 04-15-2011 03:18 PM
Crunch GPV 2000.1 Stumped... Racerkid15 General Car Audio Discussion & Questions 2 12-16-2010 12:30 PM
noob question but im stumped tylork92 General Car Audio Discussion & Questions 22 06-13-2010 11:29 AM
