Was my mechanic blow smoke? - Car Audio Classifieds!
Old 09-12-2014, 09:50 PM
0/11 sssssss18
Default Was my mechanic blow smoke?
About 2 weeks ago my alternator broke off the bracket of my car and left me with out a car for a week.I took my car to the closet mechanic to my house on a Saturday and the mechanic went on about how my Mike Singer alternator was too heavy and not aligned right.Note that I Had the alternator installed for 2 months with the only problem being that the ac wouldn't blow cooled air out.
Now the mechanic said that if he were to put the new one in that it would brake off again and the he was only going to put the old one in.I needed a working car so I went a head and paid the $354 to fix it. I talked to Mike Singer and he said that everything was fine with the alternator and that he didn't know what the mechanic was talking about.should I just find another mechanic to install it? If anyone has any suggestions or related experience with this problem I would appreciate it.
Old 09-12-2014, 09:56 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
Your mechanic is probably full of it but then the whole thing about your ac not working after installing the Singer alt worries me. He wants to put in the original for warranty purposes since he knows the original setup will work 100%.
Old 09-12-2014, 09:59 PM
cerwinvega_fan's Avatar
Loyal Member
0/11 sssss1788
$354 tho?
Old 09-12-2014, 10:04 PM
Might help if you list what kind of vehicle so others with the same thing can chime in.
Who installed the alternator originally? I assume it wasn't you. Sounds like a poor installation job, and although I haven't heard of it happening, I'm sure if they misaligned some bolts or torqued down the bolts with an impact wrench it could have weakened the bracket. The alt wasn't too heavy, that's ridiculous. it could have been misaligned though, hence the bracket breaking.
As for the a/c not blowing cold, that can happen if you get belt slip. How was your voltage while you had the alternator installed? If you don't have a self-adjusting tensioner on the belt it's normal for a new belt to stretch a little bit after a couple hundred miles and you need to adjust it. Singer alts. also typically have a smaller pulley and you need to use a slightly shorter-than-stock belt. Or it could just be that the shop that installed it accidentally did something to the a/c system to release the refrigerant.
I think the shop that fixed it wasn't' being completely honest with you, but I don't blame them for not wanting to reinstall something that (in their view) might break again. They don't want to have to warranty aftermarket stuff. I also have the feeling like the original shop (or whoever) that installed it might have not done the best job, but that's just speculation.
Old 09-12-2014, 11:11 PM
0/11 sssssss18
yea, I had a friend install the alternator at first and it worked great for the 2 months at 15.4 volts running a Crescendo BC 2200 at 2 ohms on 2 XS power D1200s I don't know if I hit a deep pot hole that would cause it to come loose but Before it broke it was making a squeaking noise for a couple weeks.I thought that I would have someone look at it after I had the rest of my audio installed at the shop. I drive a Hyundai Accent 2006 1.6 l
Old 09-12-2014, 11:20 PM
0/11 sssssss18
How much does it usually cost to have an alternator installed? The $350 was also for the belts and the oil filter he had to replace from the alternator falling on it and causing it to leak. I also think that he didn't want to put it in because he kept telling me weight was the problem and not even comparing the alternators but just by making assumptions by looking at the engine when I got there.
Old 09-12-2014, 11:46 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
No such thing as an alt too heavy lol.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 09-13-2014, 12:37 AM
0/11 ssssss535
Curious as to how much of a weight difference the alts have.
Old 09-14-2014, 09:24 AM
0/11 ssssss211
Even if it weighed 5 more lbs the difference is negligible so long as it is properly secured. Now if the place where the bracket bolts onto the engine doesn't utilize the best possible leverage points, then I can see there being an issue because the extra weight creates more torque on the bracket when the vehicle is going over bumps/potholes/etc.
If You post pictures of everything I'm sure you'll get better responses.
Old 09-14-2014, 09:28 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
IMO the only thing that can cause it to break off (since the bracket should be over engineered for the stock alts weight any ways) is the extra torque/drag created by the higher resistance from making more electrical power
weight difference shouldn't be more then 5-8 pounds different unless the case size changed in which id guess 12 pounds at most
mnguyen34 (09-14-2014)
The Mechanic iamsonic Movie & Gaming Review 12 11-15-2011 10:09 PM
Local mechanic by tomorow!! 614 columbus kn0wledge000 General Automotive Chat 3 04-10-2011 02:53 AM
Louisiana Mechanic SpeakerBox General Automotive Chat 8 02-23-2011 02:32 PM
Anyone a mechanic? djm4rshm2llow General Automotive Chat 17 09-18-2010 12:29 AM
redneck mechanic in london? korey_hofer General Automotive Chat 4 04-17-2010 07:52 AM
