Any Idea - Car Audio Classifieds!
Old 10-01-2014, 09:15 PM
0/11 sssss1076
Feedback Score: 24 reviews
Default Any Idea
I have a 2004 gmc envoy xl. I notice that my driver side headlight was out so went to replace it and it fried my pigtail. So I replaced the connector and put new bulb in and it didn't even light up. Checked fuses and they were fine. I took the whole headlight out and unplugged it from the other connector that controls the low and high beam and checked that as well power and juice on one side and power but no juice on other side.
Old 10-01-2014, 09:58 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
My dad has a 03 envoy.
What do you mean by "fried the pigtail" ?
Trace the wires all the way back to the battery/fuse blocks. Probably melted a wire somewhere down the line. Should have checked that before putting a new bulb in.
team graham
Old 10-01-2014, 11:55 PM
0/11 ssssss384
Something I would check for is corrosion from the fried pigtail back towards the factory wiring. I've seen a handful of headlight wires that corroded severely causing the resistance that is typically to blame for the pigtail roasting in the first place. Sometimes you get lucky and it only goes back a few inches but sometimes it is considerably worse. Good luck, OP.
Old 10-02-2014, 12:14 AM
0/11 ssss31258
usually the fried plug culprit is the 'upgraded' bulbs which draw too much current.
and if the bulb doesn't work, it's probably messed up too.
assuming your wires have power and ground (ohh yeah, a bad ground can cause all this too)
the easiest fix is a plug and play xentec hid kit
jrplayer36 (10-02-2014)
Old 10-02-2014, 07:41 AM
0/11 sssss1076
The old bulb was fried as well by the prongs, this seems to be a problem on envoys and trailblazers the bulbs get hot enough to melt the pigtail/connector.
a new idea? mcmuffin General Car Audio Discussion & Questions 37 05-03-2012 09:49 PM
Anyone got an idea mythyone General Car Audio Discussion & Questions 0 04-25-2011 10:10 PM
Here is an idea... Memphistahoe02 Announcements - Suggestions - Feedback - Support 3 04-13-2011 01:49 PM
Good idea or Bad idea? Ccab81 General Car Audio Discussion & Questions 6 02-16-2010 06:31 PM
New enclosure idea, but I have no idea how to calculate it... 98AckCL23 Enclosure Discussion & Design Construction Help 15 08-21-2009 04:45 PM
