97 tahoe brake lights problem - Car Audio Classifieds!
Old 11-15-2014, 01:24 PM
0/11 ssssss378
Default 97 tahoe brake lights problem
Hi, I have a 97 chevy Tahoe 4 door 4x4 with the 5.7 vortec. Just recently I noticed my brake lights are not working. The 3rd brake light lights up and cruise control still works ill have to double check on the cruise, fuses are good, bulbs are good and tail lights and turn signals work.
Before I start replacing stuff any know problems with brake lights and fixes for them. I did search online and the things I came up with are the circuit boards in each tail light, or the brake light switch above the brake pedal, which if that was it why would the 3rd brake light still light up
So if any one with a Tahoe, Yukon, suburban, or Silverado have had these issues and fixed them please let me know, it would be greatly appreciated
illinois4life
Old 11-15-2014, 01:59 PM
0/11 ssssss292
I was gonna say switch until you mentioned the circuit boards. Have someone hold the brakes or pump them while you use a test light in the sockets to see if thats the cause. Also check for corrosion inside the bulb sockets or contacts that arent making connection.
The Following User Says Thank You to Deegan2 For This Useful Post:
sthrnbumpn (11-15-2014)
Old 11-15-2014, 02:28 PM
0/11 ssssss341
Replace the boards in the lights. 5 minute job. It happens to all of them eventually.
Old 11-15-2014, 06:12 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Hmm interesting. I have the same year and have had mine for 8 years now and all I done was change 1 light bulb.
How often do the taillight circuit boards go out?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 11-15-2014, 06:36 PM
0/11 ssssss378
ok ill go to the local scrap yard and try some different circuit boards, but would the tail lights and turn signals still work if the circuit boards are bad, and I was doing some more research on it and some people have problems in the wiring in the back by the bumper, or with trailer light wires, im going to check into the wiring tomorrow, its snowing here and dark now, also seen a few people with a almost broken wire going to the brake switch which I haven't checked yet
thanks everybody for the help, ill keep you posted if I figure out the problem
illinois4life
Old 11-17-2014, 05:54 PM
0/11 ssssss378
I fixed my brake light problem, didn't make it to the scrap yard just too damn cold here 0 degrees with wind chill. But last week I used my hazard lights, and the button was kind of sticky, didn't think anything of it, I was playing with the button earlier and the brake lights started working. also had this problem with my power window locks button it was sticky and sticking, messed with it till I got it unstuck, so always check the buttons.
Also thanks for all the help and suggestions
illinois4life
Old 11-20-2014, 11:58 AM
0/11 ssssss378
well brake lights are still working, that's a good thing. just cant believe it was a sticking hazard lights button
illinois4life
Old 11-20-2014, 12:22 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
The problem I had was the brake light switch above the pedal,the nut came loose and had my brake lights on all the time.
My game is legit,
Tahoe Tail Lights agp1976 General Automotive Chat 3 03-05-2012 10:11 PM
Brake help tymoto21 General Automotive Chat 15 04-06-2011 11:59 PM
Anyone ever have a problem like this with a Tahoe/Denali TrUnK WaNgIn' General Car Audio Discussion & Questions 9 08-03-2010 04:02 PM
Electrical problem? Big 2/3, 3 batts. And lights/ACC is flickering when cars on?? AuZy_AuDiO General Car Audio Discussion & Questions 8 04-08-2010 02:07 PM
First brake job tater General Automotive Chat 10 06-11-2009 06:42 PM
