Aluminum chassis - Car Audio Classifieds!
Old 01-21-2015, 12:28 PM
Default Aluminum chassis
Anybody know of any high powered drag cars using aluminum for the main chassis? I have access to as much as I need to build it but not sure if it would be strong enough to not twist with 1000-1500hp
Old 01-21-2015, 07:37 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Many people have tried likeChassis Engineering,Chassisworks, Andy Mcoy and so on but nothing piratical or safe for many passes at the track. Formula 1 cars and Bikes is
aluminum alloy formed pieces not tubing. It can be done if one was to do a ladder stule chassis.
Old 01-23-2015, 08:22 AM
Figured, I can make a tube chassis pretty easily with the equipment I have at work guess I could just use steel. It won't be a street car, no vin or anything, so wasn't sure if it would hold of not. Mr. 92k1500 said I should get a gnx and swap in a 2jz that sounds fun to I guess.
Old 02-23-2015, 02:53 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Can you build a go-ped frame? How much would you charge?
team graham
Old 04-14-2015, 11:57 AM
Is Low-Passed @40hz
0/11 ssssss243
Aluminum would be far to weak for a tube frame car, not to mention it'd be heavier when accounting for necessary wall thickness compared to 4130.
Plus you could never run it anywhere without a cert. Lookup the 25.3-25.5 cert specs.
However, you could trade it for a tube chassis, as it should be worth mucho dinero me amigo.
Old 04-14-2015, 12:00 PM
Is Low-Passed @40hz
0/11 ssssss243
Andy McCoy is not in the habit of building safe cars, lol.
Let's settle this... Chassis grounds vs. negative runs. TaylorFade General Car Audio Discussion & Questions 94 07-28-2013 10:05 PM
Chassis grounds. You're doing it wrong. (+ giveaway!!!) TaylorFade General Car Audio Discussion & Questions 45 06-19-2012 10:33 PM
engine block to chassis ground ??? poundstone General Car Audio Discussion & Questions 11 10-30-2010 11:14 AM
American Bass XD3000 chassis specs toolmaker General Car Audio Discussion & Questions 0 06-29-2009 10:09 PM
