Removing badge from car? - Car Audio Classifieds!
Old 08-13-2015, 03:42 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default Removing badge from car?
I got that Toyota badge thing a while back and want to put it on my car. Is it just held on by glue?
team graham
Old 08-13-2015, 04:44 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Double sided tape, use the usual methods to remove emblems.
Heat gun, floss, mineral spirits, etc...
The Following User Says Thank You to craiggus365 For This Useful Post:
graham (08-13-2015)
Old 08-13-2015, 04:45 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
I've never removed a badge so I have no idea what the usual methods would be, but I will break out the heat gun and give it a shot, thanks!
team graham
Old 08-13-2015, 04:53 PM
Partially Unwound
0/11 sssss2697
The heat softens what ever held it in place, hair dryer on high works ok too.
Are you removing the factory emblem? If so you will prob need some sort of solvent to remove the residue. Even goo-gone or WD-40 will work with some elbow grease.
Old 08-13-2015, 06:25 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
I have an actual heat gun. Yeah it's the factory emblem. I'll post some pictures when I get it off. I don't want to mess the paint up
team graham
Old 10-28-2015, 08:34 AM
0/11 sssssss63
There are tons of ways but all of them take effort.I prefer heat gun and plastic scrapers or gift cards to get the bulk of it off.For long worded ones I'll use dental floss to cut it off so I dont break them.Lastly one thing that I've found to work very well on some glues and pine sap is RainX.Yeah there are cheaper things but if it is a sensitive area give it a try and you'll be pleasantly surprised.
Old 10-28-2015, 09:52 AM
massivespl's Avatar
0/11 sssss8409
I use goo gone and let it sit for alittle but and just alittle elbow grease and they come right off
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-28-2015, 09:53 AM
colorblind83's Avatar
drug mule for speakers
0/11 sssss2084
Feedback Score: 32 reviews
be careful though, some badges are not just glued on.
If I were gay I would marry you.
Funny how a girl stops talking to you when you say you would rather be homeless and give her nothing than have a kid...women...
Old 10-28-2015, 10:19 AM
0/11 sssssss63
Good point,although its usually on older cars.I always check behind the panel if possible and assumed most others do the same.If in doubt use the dental floss/fishing line method to cut through the double stick tape.If there is a bolt or threaded stud etc you'll find out before breaking the badge
Old 10-28-2015, 10:26 AM
0/11 sssss2084
Originally Posted by FourRings View Post
Good point, although its usually on older cars.I always check behind the panel if possible and assumed most others do the same.If in doubt use the dental floss/fishing line method to cut through the double stick tape.If there is a bolt or threaded stud etc you'll find out before breaking the badge
On 2010 Chevrolet Tahoe the front and rear bow tie have studs
Free Personalized Badge From Toyata rdooski3 Hot Deals 52 08-27-2015 12:55 PM
Removing 6x9's topdawg General Car Audio Discussion & Questions 16 04-18-2012 05:00 PM
ab 500.1 bottom plate and top ab badge lincoln ls Wanting to Buy (WTB) 0 02-02-2012 08:11 PM
WTB kicker SWX module and ZR360 badge xxxbasshead Wanting to Buy (WTB) 11 02-01-2011 06:14 PM
2009 Boy Scout Badge of the Year - Nominations upzaw2000 Annual CACO Awards 34 01-31-2010 04:56 PM
