Lost All My Car Keys :/ Help!!! - Car Audio Classifieds!
Old 09-30-2015, 05:11 PM
nkrell11's Avatar
0/11 sssss1420
Default Lost All My Car Keys :/ Help!!!
Lost my keys for my 04 Grand Prix. It's a long story that surprisingly doesn't involve alcohol. They're roughly 13 hours away in Minnesota and the hotel can't seem to find them even though I know exactly where they should be in the room. Just wondering the most cost effective replacement, apparently from what I've read I can call a locksmith or potentially go through the dealership.
Jeep Build Log:
Daily (Rebuild Pending)
Old 09-30-2015, 05:22 PM
I'd call the dealership and see if they can cut some new ones. If there's any transponder type deal the dealership's probably the only one that can do it; but they should be able to make new ones if you give them the VIN. They might require you to bring proof of ownership or possibly even the whole car to them to do the work.
I just went through this not too long ago but luckily found my key, lol.
Old 09-30-2015, 05:31 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
The transponder can be programmed once in the car.
To get in the car on the cheap, buy a blank key that fits your door lock.
Use some magic marker on the edges that are flat but would normally have the saw tooth pattern.
Insert the blank in door lock and twist back and forth to leave impression in the ink, dry erase may be easier to see than Sharpie.
Use a triangle metal file to manually 'cut' the ridges, it's going to take some trial and error, and a vice to hold the key during this filing is helpful.
The more worn your lock is the better this method works.
The transponder to start it can be found much less than dealer prices at some locksmiths.
This method will get you in the car and if you cut careful enough, another 'real' key can be cut from your handiwork.
Good luck.
The Following User Says Thank You to craiggus365 For This Useful Post:
socalxj (09-30-2015)
Old 09-30-2015, 05:45 PM
doug118's Avatar
0/11 sssss4674
Straight out of the how to steal a car handbook ^^^ lol
Go to the dealer with your registration or title and they will cut you a new one
Old 09-30-2015, 05:46 PM
nkrell11's Avatar
0/11 sssss1420
Well I had two sets but one of my chipped keys had to be sacrificed for my remote start. I might call the hotel again tomorrow and triple check. Hopefully they don't need my car at the dealership because it would need to be towed.
Good luck.
I can already get in to the car I don't lock it at work since it's a gated facility and there's nothing to steal out of it right now.
Jeep Build Log:
nkrell11's Avatar
0/11 sssss1420
Idea of what it will cost?
Jeep Build Log:
Old 09-30-2015, 05:48 PM
massivespl's Avatar
0/11 sssss8409
So take the key out ur remote start and go get it copied
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-30-2015, 05:51 PM
nkrell11's Avatar
0/11 sssss1420
Idk where it is in the car I didn't install it. I was told it wouldn't come out.
Jeep Build Log:
Old 09-30-2015, 06:52 PM
Partially Unwound
0/11 sssss2697
Hey, don't reveal my previous endeavors
BTW - I lived in Newark NJ for a portion on my life, these things are a given there.
Old 09-30-2015, 06:53 PM
Partially Unwound
0/11 sssss2697
The transponder will and my ghetto method + your transponder = starting vehicle.
Chipped Keys Dirty101 General Car Audio Discussion & Questions 13 01-05-2015 12:39 AM
Anyone ever installed advanced keys.... the push to start cliff1528 General Car Audio Discussion & Questions 28 09-14-2013 11:37 PM
Go to google and play with the thangy ma bobber with keys! ThatChevyGuy Off Topic Chat 4 05-23-2012 06:32 PM
Guys.... I lost my keys 1-12-t1 Powder Room 13 03-26-2012 10:17 AM
lowering kit for 99 4wd blazer blocks and torsion keys xmikedxl Miscellaneous Stuff For Sale 7 11-30-2011 01:55 PM
