Low coolant warning light - Its not low tho..??? - Car Audio Classifieds!
Old 11-23-2009, 10:06 PM
0/11 sssss1741
Default Low coolant warning light - Its not low tho..???
Ok so i had to drain some coolant due to i had to remove a couple coolant lines on my 96 continental, to change the steering pump. Well, after filling it back up and to what it seems all the air is out and everything. The damn low coolant warning keeps coming up. The car never gets hot either. The weird thing is, the coolant reservior is FULL. By full, i mean its practically overflowing, or is when hot i dont know. Ill try to get some out. But im wondering why it might be saying low coolant now, when its obviously not and not getting hot. It worked perfectly fine before this and that warning never came up. Its annoying to see it everytime i start the car.
Old 11-23-2009, 10:09 PM
0/11 ssss31257
Most likely cause is a blocked thermostat or one which has been installed backward.
Old 11-23-2009, 10:10 PM
0/11 sssss1143
is the radiator filled all the way up? mine does the same thing. im to lazy to change out the sensor.
Old 11-23-2009, 10:11 PM
try grabbing the the hose that comes from the radiator into the water neck you should feel water in it if not you might have an air bubble making it so your water pump doesn't work
Old 11-24-2009, 03:27 PM
0/11 sssss1741
Well you cant tell on the radiator actually. The reservior is seperate from the radiator itself, and the reservior has the cap on it. Its FULL. I actually need to remove some. It would seem the thing is full, and working right cuz it never overheats. So i dont think it has air, but possibly i guess.
I felt the hoses, seemed to be full of water. I dono, if you have seen the 96 or similar continentals its kind of a weird set up.
Pretty sure its not the thermostat, i never removed it. And it doesnt overheat.
Old 11-24-2009, 07:33 PM
0/11 sssss1741
Well i took a bunch of crap off to get to the bottom of the reservoir. Found some crazy looking sensor that wasnt in where it should be. Kidna just hanging there. I have no clue how that thing works, nothing leaked or anything. But it went in the bottom of the tank. Working fine now.
Old 11-24-2009, 07:40 PM
0/11 ssssss436
My reservoir sensor hangs there, if your talking about inside it. Literally goes up and down depending on how much its full, and only goes off when its more than a quarter empty.
Old 11-24-2009, 08:21 PM
0/11 sssss1741
Nope its not even inside the coolant. It goes in through the bottom of the tank in a slot thing. But no coolant can come out, so its really weird. I dont even know how that thing works. All i know is i shoved it back in there and it doesnt show up anymore.
Old 11-24-2009, 08:23 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
Feedback Score: 41 reviews
if they get stuff on them the sensor will read false readings. or the sensor is going bad. when they go bad they will turn the light on.
what vehicle?
Old 11-24-2009, 08:45 PM
0/11 sssss1741
what vehicle?
1996 Lincoln Continental.
Its working fine now.
FS: Focus Coolant Tank Cover fasfocus00 Miscellaneous Stuff For Sale 0 10-03-2009 11:23 PM
i can see the light snoopysnooper Uncensored Off Topic 13 10-01-2009 05:16 PM
Light Box blackhawk Announcements - Suggestions - Feedback - Support 1 09-15-2009 09:37 AM
[SOLD]LiteGlow "Light Dancer" Musical Light Controller toolguy420 Wiring, Electrical & Other Installation Equipment 5 09-02-2009 02:12 PM
flash light fatpat1080 Miscellaneous Stuff For Sale 7 06-08-2009 10:33 PM
