both driver's side windows wont roll down - Car Audio Classifieds!
Old 06-15-2016, 01:28 PM
Kcbme's Avatar
0/11 ssssss526
Default both driver's side windows wont roll down
Recently both windows on my driver's side stopped working,no click or noise when pushing down the window switches. Took the door panels off and the track moves so I'm assuming nothing is locked up. I have never dealt with 2 windows going out at the same time and I feel it might be an electrical issue,any help would be appreciated.
2001 chevy suburban
2001 suburban
2.8:1 4th
4 db drive wdx 7k 18s on 2 crossfire 8ks
Old 06-15-2016, 01:31 PM
0/11 sssss1475
Sounds power related, have you checked the fuse and relay?
99 s10 Blazer 2 door 5.7L Vortec swap
4- Team Ascendant Audio 18's
4- Ampere 8.0 TFE's
2- Zed Leviathan's
20 banks Maxwell caps
Team Ampere - Team Heavy Flex +160dB
Old 06-15-2016, 04:03 PM
The connector at each window motor should have two contacts- one with 12v+ and the other ground to make the window go one way, and reversed polarity to make the window go the other way. Unplug the motor connection and check to see if that's what you get on the connector that plugs into the motor when pressing the switches. If you have power at these connections suspect bad window motor. If there's no power suspect bad window switch. I don't know about the 'burb, but typically power and ground go through the drivers door switch first before going to the rear door switch, so if neither switch is working you should suspect the drivers door switch.
Old 06-15-2016, 05:16 PM
mega fatty
0/11 sssss6008
have you tried the rear window from the rear window controls?
my car the rear passenger window works from those controls but not from the driver controls
that would tell you the switch is bad on driver
Old 06-15-2016, 07:15 PM
Lock up your daughters!
0/11 sssss1342
The plugs on my window switches rattled loose. Have to push them in while rolling up/down the windows now. Super annoying
My Silverado:
Old 06-15-2016, 07:36 PM
Kcbme's Avatar
0/11 ssssss526
I havnt had much time to look at it but I did try the back window switch and it didn't work either. I'll try some of the suggestions when I get some time. It makes sense that if the front window feeds power to the rear and a front switch went out why I'm having this issue. Just didn't think 2 motors would fail at once.
2001 suburban
2.8:1 4th
Walled Ext Cabs, Center, Top or Driver side? ChevyBoy95 Enclosure Discussion & Design Construction Help 9 12-17-2014 11:01 PM
Anybody ever do subs up port driver side and great success in a suv??? Mnorwood01 General Car Audio Discussion & Questions 11 11-25-2013 12:09 PM
Driver's side speaker cutting in and out 30Hertz General Car Audio Discussion & Questions 10 11-15-2012 08:17 PM
Listened to ya about facing subs foward, port to driver side. __d_a_v_i_d__ Car Audio Videos 6 08-19-2011 06:53 AM
