300m electrical issues - Car Audio Classifieds!
Old 08-25-2016, 01:20 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default 300m electrical issues
I swapped the alternator and apparently it was tested bad at auto zone
swapped for a new one yesterday.
lights on dash and stock head unit flickering.
is this a ground issue? Or what?
brand new battery and alternator.
I drove it for a but yesterday.
it was charging at 13.8 or so
made sure lights were off when i got out
battery dead this morning.
on the charger now.
team graham
Old 08-25-2016, 02:10 PM
zsh8me2's Avatar
0/11 ssssss109
I've gotten bad parts from autozone out of the box, have them test it (assuming install was done correctly )
The Following User Says Thank You to zsh8me2 For This Useful Post:
graham (08-25-2016)
Old 08-25-2016, 04:13 PM
zsh8me2's Avatar
0/11 ssssss109
If you have a ammeter, you could check for stray current pull
graham (08-25-2016)
Old 08-25-2016, 04:42 PM
mega fatty
0/11 sssss6008
If it drives then dies over night I would suspect something is shorted causing current draw all the time
The Following User Says Thank You to tymoto21 For This Useful Post:
graham (08-25-2016)
Old 08-25-2016, 07:41 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
I sanded and scraped all the stock ground under the hood. It was pretty bad. That seems to have stopped the flickering. Resting at 12.95
I installed a volt meter too.
Idle voltage is 13.6~
is this normal? This was after a full 2a charge from the charger.
I also removed the door bulbs and did an led swap for the 2 dome/map and rear handle locations.
team graham
Old 08-25-2016, 09:40 PM
When did you replace the battery? If it was before the alternator install and the alt failed it would have severely drained the battery. It could just be that the battery wasn't sufficiently recharged. Cleaning the grounds was probably a good idea. If you're at 13.8v and 12.95 resting you shouldn't be having any problems. If the 12.95 was just a surface charge immediately after shutting off the car you need to wait for a while or turn the headlights on for 20 seconds or so to remove any surface charge and get a "real" resting voltage.
graham (08-25-2016)
Old 08-25-2016, 11:19 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Currently resting at 12.78
team graham
electrical issues/questions jd93kid General Car Audio Discussion & Questions 23 07-08-2013 09:57 PM
Electrical issues: WTF is going on? Raptor660 General Car Audio Discussion & Questions 29 02-01-2013 05:01 PM
Having electrical issues! HELP Raptor660 General Car Audio Discussion & Questions 3 07-04-2012 01:42 PM
Having electrical issues with my car Ryan1126 General Automotive Chat 12 11-13-2010 06:26 PM
got some electrical issues. need some halp giganticprune General Car Audio Discussion & Questions 3 06-10-2010 05:29 PM
