Frost on inside of car - Car Audio Classifieds!
Old 01-03-2010, 10:32 PM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
Exclamation Frost on inside of car
For some reason I get frost on the inside of my car's windshield and windows. I'm not sure why... There is none on the outside though.
It really pisses me off too.
I have a '91 Chevy Caprice if that helps any.
Maybe my doors don't seal shut?
Refs: BlackWaterOp x2, Master69 x3, Scottie x3, RidnClean, JusBlaze (Scammed Me), SPLaudio x3, ltr450racer690, dbeez, LuisT, SPY, Mgcauctions09 x3, pieper88 x3, scottyk, Jh8909, JB312, stretch, Mechman, 01SpyderDB23, andrewtexas123, 50 black guys, bubbagumper6, btr, SacTownBully84
Old 01-03-2010, 10:34 PM
0/11 sssss6061
You have a lot of junk in your car?
Old 01-03-2010, 10:35 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
Feedback Score: 41 reviews
mine does it also. just from holes i havent sealed off, and bad seals. any moisture that gets inside is trapped. this is why my truck is being stripped on the inside and every day hole i do not use will be welded closed.
check where you ran any power wires through metal also. that will do it
Old 01-03-2010, 10:36 PM
mattj's Avatar
0/11 ssssss310
Either you have a water leak somewhere or usually a pool of melted snow can cause that too. Pull your floormats and leave them inside overnight by a fan, and let your car run for like an hour to hour and a half with defrost and floor on full blast. That should dry everything out.
If you still have problems with frosting, you know you have a water leak somewhere.
2002 Pontiac Bonneville SSEi
Pioneer F90BT
Knukonceptz 1/0, 4, Inlines, RCAs
RD Audio 1800.1
RD Audio Heavyweight GP 12"
Crescendo 1000c4
RD Audio Alpha 6.5 comps F
Crescendo CCX52 comps R
Old 01-03-2010, 10:38 PM
got160s?'s Avatar
0/11 ssss13630
My guess is seals.
I had the same problem in my Monte.
Vehicle: 1999 Chevy Suburban AKA The Bammin' Beast
Battery: 25 XS Power XP1000's
Sub Amp: 3 DC 9k's
Sub Stage: 18 DC Lvl 4 M2 12's in a Nasty 4th Order
Subscribe now! Prizes will be given away for every 1000 subscribers!
Old 01-03-2010, 10:42 PM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
Like what? Lol, and no I have barely anything actually.
Well I ran my power wire under so that isn't a problem.
Must be a water leak then because I keep my car in my heated garage with the windows rolled down so it dries everything out every night.
Originally Posted by 2loud4youmorris View Post
My guess is seals.
Yeah, I'm thinking it's my door seals. I thought one day I could see daylight through them once lol.
Old 01-03-2010, 10:44 PM
got160s?'s Avatar
0/11 ssss13630
Try door seals.
That will be a huge part.
Especially if you can see the sun thru your door.
Also try to tighten your door hinges.
Sub Amp: 3 DC 9k's
Old 01-03-2010, 10:45 PM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
Try door seals.
What should I do to them? Just replace them?
Old 01-03-2010, 10:50 PM
mattj's Avatar
0/11 ssssss310
You could. Id try the free method first by pulling floor mats out to dry inside overnight and let your car sit for an hour or hour and a half on high heat on defrost and floor.
Pioneer F90BT
RD Audio 1800.1
Crescendo 1000c4
got160s?'s Avatar
0/11 ssss13630
Try to see if there are any holes or gaps or even rips and cilicone them.
If not then try to make sure they are on all the way.
If that doesn't work come back to me.
Sub Amp: 3 DC 9k's
Tags
caprice, frost, windshield
resin inside box gbo559 Enclosure Discussion & Design Construction Help 14 12-18-2009 06:59 PM
Big oops pic inside GODHATESCIVICS General Car Audio Discussion & Questions 31 11-30-2009 03:01 AM
Frost?? splvictim20 General Car Audio Discussion & Questions 15 01-17-2009 11:50 PM
Xbox 360:::::Look Inside connersdad19 Miscellaneous Stuff For Sale 0 01-14-2009 06:50 PM
Ufc 92 (Spoilers Inside) Patrick Simmons Sports and Fitness 14 12-28-2008 02:32 PM
